1989 C4 gas gauge not working...
Old 05-26-2016, 09:37 AM
Gloria B
7th Gear
Gloria B's Avatar
Default 1989 C4 gas gauge not working...
Good Morning! My gas gauge isn't working (ugh). Previous owner claims that he had tank dropped and repaired. Any suggestions as to why it is not working would be appreciated! TY!
Old 05-26-2016, 09:44 AM
antfarmer2
antfarmer2's Avatar
Tank is very hard to ( drop ) so have my doubts. But the pump unit is very easy just take the fuel door off then the bib a few screws and hoses and pull it. Repair or replace.
Gloria B (05-26-2016)
Old 05-27-2016, 04:08 AM
Cliff Harris
Cliff Harris's Avatar
My guess would be a bad connection at the tank. Check all the wiring in that area.
Old 05-27-2016, 11:29 PM
ghlkal
ghlkal's Avatar
Finalist 2020 C4 of the Year - Modified
2018 C4 of Year Finalist
Originally Posted by Gloria B
GMy gas gauge isn't working (ugh).
By "not working," is the gauge "way off" or does it always show Empty (or always Full)?
One common problem is with the sending unit in the fuel tank. This has the float that raises or lowers with the fuel level. The sending unit is fairly easy to access by removing the gas filler door, and then unbolting the top (which contains the fuel filler neck). The sending unit will pull out from the top of the tank (no reason to drop the tank).
Good luck.
Old 05-28-2016, 12:13 AM
HAD2HAV2
HAD2HAV2's Avatar
Gloria B, If you are not mechanically inclined you need to take your car to a good shop and have the fuel area looked at and maybe remove the fuel pump to solve your problem. Doing this yourself is not hard but can be challenging.
Old 05-28-2016, 03:46 AM
Cliff Harris
See this for fuel level sender removal/fix/replace:
https://www.corvetteforum.com/forums...h-article.html
Old 05-28-2016, 10:37 AM
c4cruiser
c4cruiser's Avatar
That's a good article but it looks like all of the pics have been removed from one of the old CF Servers. The tread is 10 years old.
This thread may be of some help as it does have a few pics.
To 1989 C4 gas gauge not working...
Quick Reply: 1989 C4 gas gauge not working...
