Ppower Steering Fluid
As I go through replacing the fluids on my 94, I went to the GM parts dept with my manual in hand. According to them, they don't even cross the PS fluid part number listed in the manual to a later fluid and the original number is discontinued. They told me that the original was synthetic and was made for easier steering in cold weather, and that GM doesn't use a synthetic any longer.
The original part number is 12345866 or 5867 (different size containers). What they sold me was P/N 19329448.
I have not really planned on a full flush, but do a drain the reservoir refill it with new and after driving it repeat multiple times.
Is there any issues with the fluid that they provided? I'm assuming I don't need synthetic, especially since I don't drive in cold weather. (often).
Since no one has answered I'll tell you what I did. I have an '86 and used a NAPA branded generic power steering fluid, #9832. I used your suggested process of draining and refilling the reservoir multiple times, with driving in between refills. I have had no adverse affects.
If you want to stick with a synthetic I'm not sure but you could check Amsoil, Lukas or possibly Red Line. Will probably have to order on line tho for those.
Scooter94 (06-03-2016)
Redline is an excellent choice. I have also used Lucas and have no complaints. Redline seems to be the fluid of choice for the racing crowd.
edit- Lucas you can pickup locally. Redline order from Amazon.
I used synthetic Redline power steering fluid. What a BIG difference in smoothness and reduced the amount of energy needed to turn the steering wheel. Since I have learned that Amsoil makes a synthetic p/s fluid which I'm sure works fantastic. I used Amsoil synthetic auto trans fluid recently and could not believe how well it worked, shifts smooth as glass.
I think I'll look for the Redline PS fluid.
Go with the Redline synthetic P/S fluid, it meets GM Spec Number 9985010, several of us have been using it for years with excellent results:
http://www.redlineoil.com/product.aspx?pid=79&pcid=27
https://www.corvetteforum.com/forums...ing-fluid.html
https://www.corvetteforum.com/forums...t-gives-2.html
This thread is an interesting read on P/S fluid for late model C4's that originally required P/S fluid with GM's 12345866/7 spec;
https://www.corvetteforum.com/forums...-ps-fluid.html
Been using this 100% in the reservoir for over ten years in my '87. Works perfectly.. No leaks, great feel.
http://lucasoil.com/products/problem...ring-stop-leak
I really like the Red Line synthetic PS fluid. It works very well to handle the heat generated from high RPM operation such as track use or even autocross.
I don't think synthetic is necessary in your situation. But the Prestone fluid for American cars is fully synthetic:
http://prestone.com/enmx/products/ca...s/product_list
Also, power steering fluid isn't a regular service item but after this many years it's probably a good idea to freshen it up. That's why I did it, there were no problems, I just wanted fresh juice in everything
It smells pretty strong and is dark in color. Sounds like cheap insurance.
This the right stuff????
I use royal purple synthetic power steering fluid with a little bit of the Lucas stuff in it to condition it. Works well.
