cruise control not working
Just replaced clutch master cylinder and cruise doesn't work. It did prior to my work. The "cruise" indicator does not show either. I tried messing with the switch at the top of the clutch and brake pedal and it doesn't matter. Is there another switch somewhere or a wire I may have pulled?
Just reach up under the dash and cut the hose. The cut it a few inches long ways el tape a wire in it and lube it up. Pull it through and reverse to install. Then put a connector on it. Right by the firewall where you cannot see it will feel like a dead worm and loosening vacuum pull gently so you do not break it.
http://www.superchevy.com/how-to/vem...ontrol-repair/
http://www.superchevy.com/how-to/82001/
These articles describe what to do. I went through them and it is pretty straight forward. If you need a new servo I have a spare that is just sitting in the garage. I will let it go cheap.
