fuel and spark no start New to the cfi
Old 06-24-2016, 08:49 PM
hemetsfinest
hemetsfinest's Avatar
Default fuel and spark no start New to the cfi
What I have done icm coil plugs wire distributor cap rotor...had a Alternator wire melt to the motor fixed that and bought a new alternator way running perfect for 2 days it did back fire 2 times both when I stomp the gas 3rd day on the way home it was idling high about 1200 rpm and I made it home Sat for a second was still high shut it off came to start again and Nuttin I pulled the injectors fuse to not flood and it started ran like carp but ran if I put the fuse in after it's running it will continue to run but smokes like crazy and runs horrible I'm at a loss no scanner lcd screen is out so no check engine light can be seen any help would be amazing I appreciate it
Old 06-24-2016, 10:27 PM
antfarmer2
antfarmer2's Avatar
Pull the vacuum line off the FPR and check for fuel if there new FPR and smell for fuel in the oil. Change if there.
Old 06-24-2016, 10:52 PM
kimmer
kimmer's Avatar
C4 of the Year Finalist
Sounds like you may have crossed a plug wire.
Old 06-24-2016, 11:33 PM
ccrazor
ccrazor's Avatar
St. Jude Donor '08-'09
This wont work if it's a cfi as noted in the title..
ww.neilkline.com/Tech%20Tips/obdcodes.htm use this link to use the paperclip method to check for codes..
Old 06-25-2016, 07:49 AM
divotdug
divotdug's Avatar
Sounds like mine when the front coolant sensor failed. ECU thinks it's cold and starts flooding the engine.
Old 06-25-2016, 01:34 PM
hemetsfinest
Where exactly is the sensor located
Old 06-25-2016, 01:57 PM
hemetsfinest
I found the ect and it absent been hooked up the hole time I noticed the wires when I bought it but ran fine with out it this hole time I'm sure it dident just start now right I tried to run codes and nothing cheap scanner from a parts store I can do the fpr rebuild today but hate to throw money away
Old 06-25-2016, 06:03 PM
hemetsfinest
Ok it's alive fuel pressure regulator and timing was way off loose distributor so 60 bucks well spent thank you all for the advise......my car is running with out the front ect seems just fine I will replace my it asap any tips on this seems to be a few choices
To fuel and spark no start New to the cfi
Quick Reply: fuel and spark no start New to the cfi
