Thermostat housing bolt removal HELP
A good friend of mine has a C4 85 and he was removing the thermostat housing when he broke one of the bolts off. After drilling the center out and inserting an easy out, he snapped that off also. Would a left hand drill bit help ? Or is that part of the intake which could be swapped for another intake ? It's a cross fire injection intake. I'm trying to help him find some help. The C6 group have been very helpful to me with my car, so I thought you guys may have some insight that could help my buddy. Thanks for your input in advance.
Has he been able to remove the easy-out?
There's numerous approaches to removal - the left-hand drill bit and progressing in size often works. Tools, equipment etc. that's readily available might influence the choices.
Oops my bad. It's an 84 and he hasn't been able to remove the easy out. Thanks for helping me clarify that. Is that surface that the thermostat sits on part of the intake or the block ?
Depending upon your situation I'd think that if possible and there was someone with mobile welding capabilities you consider mig-welding a nut/washer or nut and complete the extraction. It's kind of a "who do you know" and what's available in the area. Your location hints there should be "many" that could help you.
Thanks that was a great help. It looks like replacing the manifold for $199 is not too severe. You were a big help. While I have you helping me, I sold him my C6 stock wheels at a good price, but the rear ones will hit the rear suspension knuckles. What size spacer would clear that problem up ? I was thinking a 2" or less would do ? Thanks again for the words of wisdom.
Wheel spacers? If your rears are still on the ground it might be good to confirm the wheel offsets from the wheel back-side. I don't generally assume anything!
This is maybe what you should expect on your wheels:
Front: 18 x 8.5 56MM offset
Rear: 19 x 10 79MM offset
The same thing happened to me when I tried to change the thermostat on my '84. I pulled the manifold and took it to several machine shops and they all told me that a shop with wire EDM cutting capabilities would be the only place that could help because of the broken thread extractor. A buddy at a local hot rod shop took it to an aircraft machinist at the local airport and he had me back up and running the following day for about $100.
I will let him know about the MIG welding solution as well. I would tend to agree on the used source. The mounted tires just seem to hit the rear suspension knuckles, I thought putting spacers on would bring the tire away from that. It doesn't look like it would take more than a 2" to do the job. I just wasn't sure of it. The fronts fit fine. The only thing in regards to the intake is that he decided to try drilling around the edges of the easy out and I think he put a bunch of holes on the intake itself. He showed me after he did this, so that's why I told him I'd try to get some answers for him before he did anything else to make it a bigger problem.
I believe that when mounting "base" C6 wheels on an early car 1" are suggested for a front and something 1 3/8 or very close for the rears. If 1 1/4 OR 1 1/2 were less expensive "off the shelf" it might influence the decision BUT if there were no monetary savings then the 1 3/8 I believe would be the choice.
The less he messes with it and the sooner he solicits professional help the easier the repair. At this point he may very well be able to TimeSert/HeliCoil the manifold. The more he "tinkers" the more expensive the fix is likely to be.
If you visualize the C6 wheels 1" further outboard of where they would mount now I believe you'll better understand the 1" spacer suggestion for the front.
Pro Mechanic
FYI, I have a Crossfire base for sale, if you want it.
At this point, it needs to be welded on, and removed that way...then if the threads aren't serviceable due to his drilling, it will have to be drilled larger and a cert or helicoil put in (which will be stronger than the original threads, BTW).
This does not solve the current issue, but the reason the bolt snapped off is the prior owner did not apply anti-seize to the threads. Steel and aluminum will react overtime.
In the case of galvanic corrosion, the combination of two dissimilar metals with an electrolyte is all that is needed to form a reaction. The result is that the two metals bond together as if glued or welded.
That is correct. He might get the extractor out if you use a center punch and tap it clockwise to reverse the way he was trying to extract the bolt. You have to catch a edge on the extractor in a couple of places and tap to walk it out. Or weld a nut to the extractor and get it out that way.
If you get the extractor out, then I would suggest to continue to use a drill going up the next size bit until you drill out the bolt. You can then weld up the hole and fill it in. Then re-drill and tap. Or use a heilcoil insert.
