Erratic idle
Old 07-01-2016, 08:04 AM
mtschimmel
7th Gear
mtschimmel's Avatar
Default Erratic idle
my 94's engine Rpms are surging . I replaced the opt I spark and now the engine Rpms are hunting at low throttle rpm. We checked the vacuum lines and found no leaks. I also changed the IAC, alternator, battery, and water pump. Is there a reload procedure or something that I am missing.
Old 07-01-2016, 10:37 AM
antfarmer2
antfarmer2's Avatar
Check the vacuum lines again and my 94 would bog and fart new front o2s never ran better. How old are yours.
Old 07-01-2016, 10:48 AM
BadUmp
BadUmp's Avatar
Or, maybe he should try cleaning the lint trap, just run water though it and see - - - might just work . . . . .
To Erratic idle
Quick Reply: Erratic idle
