c4 airflow
#41
Pro Mechanic
What say you, about the gap shown in your pic and Ron's pic, vs. my pics and what 91 black convert observed? Build quality? The shrouds from late TPI to LT1 are the same...I think. I think even you can admit that in my pics, there is no such gap. There is no place for "cold air". Why the diff, do you think?
For those who haven't noticed, I prefer to seek out fact, rather than make stuff up and post bullsh!t. So that's what I worked on today; fact finding.
I started by taking a better pic of my front end in bright, day light. Still looking for that orifice for air...
...Maybe I need glasses. I'm just not seeing it.
My Blue Point MT586 DVOM has a temp function and a temp probe. I ran that to the inlet of my air cleaner, added some wire so it would reach into my car so I could take pics of the air temp in the filter housing area while under way. Got it all set up;
I measured the ambient air temp at 71*F, then closed the hood. Started the car and drove off. I drive about 2 min to get out of my neighborhood, then I'm on the highway, basically coasting down hill to Salt Lake; 13 miles, 2500' drop. So I'm at high speed, engine idling...that is about as good a scenario as I can imagine for "cold air" while under way.
Anyway, once up to speed and on the highway for ~5 minutes, I turned the DVOM on again; 86*F. I'd already increased temps at my filter 15* and the car wasn't even warmed up or under load. And I was traveling 75 mph. But now I'm confused, b/c I swear that BTG said;
I finished my trip in SLC got back to my house and threw a regular thermometer on the air filter, and let it sit, idling for a few minutes. Ambient temp was about 80* at that point, engine temp was 185*, car was parked in the garage (shaded) w/the garage doors open. Here was the reading;
^Thermometer is pegged, -over 120*F, or over 40* higher than ambient...that ain't "Cold" air. Like I said; I'm going to do more precise/controlled measuring once I get my DVOM fixed and report back, but maybe we need to more clearly define what "cold air" is. I don't call that cold air.
#42
Hey Tom, when you do more testing, can you also check the under hood temps to compare with the air filter temps? That would settle it once and for all.
#43
I think some people might be focussing too much on the trees and arent seeing the forest !
Remember that this early c4 intake was designed at the beginning of computer controlled fuel injection, at that stage it was about sufficient air volume to feed the TPI, which was around 550 cfm, that the engineers wanted. This can be achieved with stocksetup.
People in search of increased airflow have talked a lot about "cold air intake"
without getting into that concept too much, lets think about how all the manufacturers have developed the air intake in later years ? They have an air intake from the front of the car and funnel it into a box surrounding the air filter. This captures the air and causes a pressure at the face of the filter that it can easily draw the air from.
Performance motorcycles have gone one step further and they use this system with an airbox that creates a pressurized system.
So for the c4 system to work as a real cold air system it needs to take the air from the front and feed it into a captured air system enclosing the filter. If you just feed air from the front towards the air filter that just sits in its own void it would simply just keep on going elsewhere into the engine compartment. Air isnt that smart that it can recognise an air filter and go into it !
To understand it, look at modern efi air intakes and look at the aftermarket cold air intakes and see how they are designed.
Speed Racer X (02-06-2024)
#44
Pro Mechanic
In my '96 Silverado...and in my wife's V, the inlet to the intake system is right behind the turnsignal light...which is completely outside the engine compartment. From that inlet, there is molded plastic pipe to the air filter box...and of course a molded plastic or rubber pipe from the bod, the the TB. So no air that is influenced by engine heat can get into that air stream. Not at speed, not at rest, not at idle...never. THAT, to me, is a "cold air intake. Anything that allows the mixing of inlet air, which is all C4, 5 and 6 intakes...is not that.
#45
My $0.02
It appears to me, (not a fact), that the C4 engineers found it to be more important for the ambient air to get to the a/c condenser and the radiator than it was to get it to the engine intake. Therefore they built the shroud around them to get the ambient air directly to them, and not to the air filter.
#46
Assumptions will get us every time. Based purely on external evidence, I'm assuming most of you haven't noticed the rubber sealing strip between the hood and the top of the air filter that restricts airflow from the engine compartment to the intake when the hood is down.
And it may be that some of you are assuming no such airflow preventer is present.
Film at 11:00 after I can dig into it a bit deeper.
#47
I'm still trying to fathom the idea of hot air from behind the condensor and radiator making its way foward to the air boxes inlet while the car is in motion
"Hey Tom you want an aspirin or something"
and get a load of those pics I see the same opening ("deliberate path") as in my pics
if it serves no purpose what are the louvers or vents for
91 -96 use the same bumper reinforcement bar
and I guess they put the water diverter on the later higher horsepower higher compression engines help get more hot air from under the semi sealed under hood area into those hungry LT4 and LT5 engines
#48
Pro Mechanic
If you looked at my pics, you'll see that there is no opening ahead, below, beside above the filter for cold air to enter.
I also don't follow the "asprin" comment...nor do I understand why you keep quoting (in bold, of course) the "semi sealed hood area". Is that a hard concept to understand? The hood has seals around select areas of it's "flange". Around the wheel wells, along the cowl, for example. Other areas are not sealed: around the bottom/sides/front of engine, the bumper to hood panel gap....not sealed. Hence, my use of the term, "semi sealed". Part of it is sealed....the rest is not.
#49
Pro Mechanic
So I figured out the issue w/my DVOM. I took my boy down to watch Nitro World Games in SLC tonight. On the way home, I wanted to take observations but the DVOM isn't back lit. So, I got off the highway, cruised through our neighborhood at about 35 mph (less than two minutes off the highway to my garage). Pulled in the garage and flipped on the DVOM which I could now read w/the garage door light on. Here is some bold face for you, BTG: Ambient temp was/is 60*F. Temp at my filter was 159*F.
That's not a cold air intake.
#50
Pro Mechanic
If you knew anything about tools, you'd know how accurate the Blue Point MT586 is, and you wouldn't be slandering it. Oooor, you probably would, because your role here in this thread doesn't appear to be in seeking out fact. You seem to have other, less noble motives. A shame a fellow forum member behaves this way.
#51
Pro Mechanic
Nicest month on this forum.
Your data wasn't data. It was a pic. That is something, but it's not data.
*I* acknowledged that the car in the pics you posted does appear to have some kind of port/hole...whatever you want to call it. FYI, that is not a "deliberate path of cold air". A "deliberate path" would be a formed tubing from the filter housing, to the hole that your pic depicted -like my Silverado, and V has. Anyway, why can't you admit that my pics show no opening? It's incredibly clear. Anyone w/eyeballs can see that there is no hole. I asked you what you make of that. You lied and said that you can see a hole, but we all know that ya can't. There isn't one to see.
If you can see a hole, do this; use photoshop or some similar program, and draw an arrow pointing toward the hole in my shroud. You won't, because there isn't a hole to point to. Now....I don't know why the car in the pics you posted and Ron's pics apparently have an opening. Mine definitely doesn't (FACT, BTG -as you like to say), so why the diff? 91 Black convert's car doesn't have one, he says. The car in the pic that you posted should have the same shroud as mine, I think. Why the diff between cars?
Now I post real air filter temps. I admit that the data thus far isn't the best -more controlled testing is in order. You contribute by saying that "my pot is full of holes". That is a bullsh!t statement. Tell this forum HOW, specifically, a temp probe at the filter element, measuring 159*F on a 60* night, how is that full of holes? it's way more data than you're contributing...
#52
Pro Mechanic
your claims are nothing but a Dog and pony show
IAT's have been logged and discussed at length recently
a volt meter and a patio thermometer just ain't cuttin it
you want ambient read all about it Bubba
https://www.corvetteforum.com/forums...-cold-air.html
The car in the link appears to be an '84. This thread is about late C4's. At least, that is what *I* have been talking about. Try to keep up. If I'm making a "dog and pony show" I have no fear of being the only one, with you posting your drivel here.
#53
Pro Mechanic
What does "jamf" mean?
You already posted that. This is the third time. Why do you keep posting the same posts, over and over again? I guess that I have to repeat myself. That is an early car -an '84 I believe. Different shroud, front end, induction system, etc. Anyway, I did get similar readings to his...right after I started driving my car w/a cold engine, and coasting down hill at highway speeds at idle. In other conditions, I got different results. Why the diff between cars?
You said you saw a hole in my shroud. That was either a lie...or you're blind.
I don't know what your "mission" is in this thread...but it certainly doesn't appear to be for the benefit of knowledge.
#54
ps the car is a 1990 model try and focus Tom
Your figures don't JIBE
#55
Pro Mechanic
More repeat posts...no answers. I see a pattern here. AMF.
#56
IOW, to get a valid reading, you need something better suited for the application. Absent the proper instrument, I would suggest an RF indoor-outdoor thermometer with
o the hood down and
o the car moving.
Those two conditions are essential for any valid reading.
#58
Pro Mechanic
I think you're on the right track measuring temperatures to get to the bottom of this, but you've got a thermally conductive wire going through a hot zone (the engine compartment). The tip (which works well for point contact against a surface) WILL get raised to that temperature, absent something to cool it that's more effective than airflow past something the size of a pin head.
o the hood down and
o the car moving.
o the hood down and
o the car moving.
#59
I have nothing in front of my radiator anymore, and I cut open the shroud in front for a mod suiting the car in the past. I may close it back up at some point, but I have no problems with cooling on my car even with Chinese radiator cooling my larger than stock motor.
In stock form my car has an angled radiator that has an ac condenser in front of it, both of these units sit under a radiator shroud or almost cowl. The air filter sits in front and gets it's own air up to the intake.
People have said over and over "bottom feeder' take a minute and go look at your car or read posts from the 90's even on the net and figure it out. It's simple and nobody said it was the best design but it worked well enough to sell many thousands of cars and still have them be drivable decades later.
If you had a sealed off bottom of the car it would need a different design.
Can I ask what makes you so intrigued by this simple design concept?
#60
Even if you were right about whos "hucking slander" (your not), then it wouldn't be slander anyway. It would be Libel, but I'm not surprised you don't know the difference.
Did you ever try to deform the trim pieces as to create an air gap, similar to the earlier cars ?? I know we had talked about it in the other thread but it may have been too much hassle ...
