Shifter won't go into gear (6 speed)
Live well,
SJW
kostas86,
Regardless of the mileage the car is still 26 years old. My gut is that the master or slave is gone however I do not agree that you need to replace the parts. The "new" stuff is junk. Have your OEM master and slave rebuilt by Jim at Power Torque Systems it will save you in the long run.
http://www.powertorquesystems.com/
The aftermarket slaves have a thicker flange and about 1/2 of an inch longer length this will cause you to remove the 1-4 skip module from the trans to remove or install. The OEM unit will fit no problem. Plus MUCH better quality material. I am servicing a buddies ZR-1 now and the Chinese junk slave rod snapped causing his failure. Also this is not a difficult repair to do yourself. The toughest part is getting under the dash to remove the clip on the end of the rod for the master.
-Daniel
-Daniel
Also do you recommend going with the '91+ slave which I hear has better location for bleed screw?
This means that (hopefully) only the first-gear synchronizer saw any abuse. If you're lucky, it survived. It's a seriously bad idea to force any manual transmission into gear when the clutch isn't fully disengaging. Seriously. These ZF gearboxes are costly to overhaul, and there aren't many people who are capable of doing it right.
Live well,
SJW
Live well,
SJW
Pro Mechanic
Yeah...if you got "past" the synchros. The fact that it's not grinding...and the car is moving, and you can't get it into gear, that is proof that the clutch isn't releasing and also proof that they synchros are working their asses off. Which is why you haven't ground gears yet. Keep at it a bit longer though, and you'll get some grind...that is for sure. And then your synchro will be toast.
Thank you everyone for the feedback. Been a chaotic week/weekend and haven't got to the Vette again. I'll double check, the fluid (I can't recall the color). And just to clarify, when I was forcing the car into gear I wasn't driving, just on my driveway.
Is there a preferred clutch master and slave cylinder that everyone has been purchasing? I have read about tossing in the '91+ slave as the bleed screw is at the bottom (vs older on top) so much easier to bleed. If that's the case and no other modifications are needed, I am assuming better to go this route and reduce the amount of swears and headaches lol.
Yukon Corleone: Unfortunately I do not know any shops or have a preferred one yet for the Vette. When I replaced the waterpump and belt, I took it to the dealer as they only wanted slightly more than everyone else and included loaner.
I was debating on tackling this repair as the master cylinder appears to be fairly straightforward and the slave not too bad also.
Got mine from Rock Auto, picked a Wagner as this has a sound reputation. Not the cheapest but Wagner has a good reputation. The part came in a Centric box. Who the hell is Centric. Part has no id number but says made in China. Slave was Valeo, also a good name, made in Taiwan. I guess I can't complain as the parts were cheap, they work and they are readily available. My luck finding a remote key fob have not been as rewarding. They are rare and expensive when one is finally located.
-Daniel
kostas86 (07-22-2016)
I would say Jim's rebuilt OEM's are far better quality than anything else. He hand does each one so I would say better than the OEM was new. The OEM parts are repainted to look new as well. It is a little easier to bleed the later model but, to me, not a big deal either way. If you do send to Power Torque you will get the same parts back after being rebuilt. I will try and get a photo of the Chinese part next to Jims redone part tonight.
-Daniel
-Daniel
Took me longer to get around to snapping the photos. Below you can see the difference. The rebuilt unit from Jim at Power Torque was a used unit that he rebuilds. Hope this helps.
-Daniel
Power Torque on the left, China junk right.
Power torque top, China bottom.
-Daniel
Small update.
Just haven't been able to devote time to the Vette so I sent it to a buddy's shop that works on old American cars. With summer winding down here in Chicago, I'd prefer to have it on the road again sooner than later.
Got a call that the owner of the shop was able to pump the clutch numerous times and all the gears engaged and he was able to drive the car around normally after that. He's inspecting the master, slave and clutch and will keep me posted on his findings.
I am thinking with the transmission/clutch apart, might as well toss in a new rear main seal. Also debating about tossing in a new clutch even if original still has plenty of meat left.
#33
Pro Mechanic
#34
#35
Culprit was the slave cylinder and soaked clutch with gear oil according to shop.
New slave cylinder, heavier duty clutch and rear u joint going in. I'll ask for the the original slave cylinder back in case I ever want to rebuild it in the future. He said RMS was good and no leaks so didn't recommend I change it. Should have the car back soon.
#37
Picked up the car last night and couldn't be any happier with the shop and results. Shop specializes and builds lots of muscle cars and they are very passionate about their work. Installed a $300 full cast iron slave cylinder (forgot name) which he considers the best and should last forever and LUK clutch assembly kit.
Car has never felt better (crisp, more responsive, smoother, list goes on).
Yukon Corleone: I'll PM you their info. Highly recommend them.
Yukon Corleone (08-12-2016)
kostas86 (08-12-2016)
#39
specifically..my 92'c4 62k mi. sits...then when I go to drive will NOT go into gear... I get determined and finally muscle it in...its hard to shift the first few shifts, but then after driving for a while( warms up ??) and then shifts 'normal'.
It started this about 2000 mi ago..and now does it pretty consistently ???? where should I look first
Thanks in advance !
Val
