1992 aftermarket stereo loses power?
Old 07-19-2016, 06:17 PM
CA1992C4
CA1992C4's Avatar
Default 1992 aftermarket stereo loses power?
The aftermarket CD player on our new to us 1992 C4 either loses power, or has a loose ground wire.
The previous owner thinks it's a loose ground wire, but he is not sure. He had the CD player installed at a Stereo Shop, so you'd think it should of been put in correctly.
My question is - where on the car should I start looking for the possible loose ground wire? I Googled this question and have spent an hour looking for an answer, so you folks here are my last resort before taking it into another stereo shop.
Old 07-19-2016, 09:01 PM
champa21
champa21's Avatar
I had a similar problem, my speakers popped when turning on the car and changing channels, that is after a new head unit and plug and play harness from crutchfield, I did the online chat with them and they said the PAC SNI-1 would fix it, so I found them locally for $20.00, i needed 2, found them at an audio install shop(mobile one), the tech at mobile one said also to get a resistor and put inline with my blue/white wire on the new radio harness hook up and tie it in to the blue metra harness wire 70-1857, that didn't work with the harness, so I cut out the resistor and everything works great!!, It does pop a little when i turn off the car but I can live with that. I have a 1995 corvette with the Bose system in her and didn't change the speakers.
Old 07-19-2016, 09:22 PM
champa21
champa21's Avatar
Do you have the Bose system?
Old 07-19-2016, 09:24 PM
CA1992C4
CA1992C4's Avatar
No - he had an aftermarket CD player put in. It sounds good on smooth roads, but as soon as I hit some bumps the player stops playing until the road gets smooth again. I'm not sure what panels to take off to start looking for it.
Old 07-19-2016, 09:27 PM
champa21
champa21's Avatar
I just did my 95 with a bose system and speakers, I didnt change the speakers, and had the harness from crutchfield and had loud pops, so i chatted with them and they replied back to get the PAC SNI-1 and it fixed it, the harness has 3 ground wires and the head unit has one, I soldered all of them together and had the pop until I put the PAC SNI-1 in, now all pops are gone until I turn off the car, I can live with that.
Old 07-19-2016, 09:29 PM
champa21
champa21's Avatar
did he sold
er the wires or tape them?
Old 07-19-2016, 09:30 PM
CA1992C4
CA1992C4's Avatar
I called the stereo shop that did the install and they said the warranty was over for the car, but thy are willing to diagnose the problem for a fee - but I was hoping to find it myself if I could.
Old 07-19-2016, 09:32 PM
CA1992C4
CA1992C4's Avatar
did he sold
I'm not sure - I'm new to the car and haven't started taking things apart that I don't know about. I'd like to start taking the panels off that are where the problem might be - but I may just let the sereo shop do the job.
champa21
champa21's Avatar
did he sold
I also put in an aftermarket head unit
Old 07-19-2016, 09:34 PM
champa21
champa21's Avatar
iether a ground loop prob are a bad ground connection, it has to be sanded down to the metal for a good graound, mine didnt require it.
Old 07-19-2016, 09:35 PM
champa21
champa21's Avatar
typos, sorry
Old 07-19-2016, 09:36 PM
CA1992C4
CA1992C4's Avatar
typos, sorry
That's okay - I get them too.
Old 07-19-2016, 09:39 PM
champa21
champa21's Avatar
typos, sorry
look below the battery for a bad ground, the acis from the battery will mess it up big time, take it lose and grind it down and re-apply the ground, prob will fix it unless the ground is behind the radio and needs attention.
CA1992C4 (07-19-2016)
Old 07-19-2016, 09:40 PM
champa21
champa21's Avatar
if the radio was installed incorrectly it could also be the ground there.
Old 07-19-2016, 09:42 PM
CA1992C4
CA1992C4's Avatar
I'm heading down to the garage to check that ground. Thanks for the help!
champa21
champa21's Avatar
I would remove the radio and look at the grounds, they are all black.
Old 07-19-2016, 09:44 PM
champa21
champa21's Avatar
K hit me back
To 1992 aftermarket stereo loses power?
CA1992C4
CA1992C4's Avatar
I'll have to find a YouTube video before I tackle that - the ground below the battery will be first.
Old 07-21-2016, 12:17 AM
CA1992C4
CA1992C4's Avatar
I drove the car today and the CD player was skipping on every bump, so I switched it over to the FM radio and it never skipped the entire ride - and I tried to hit every bump in the road.
So I feel that eliminates the bad ground wire I felt was causing the skipping.
I brought it over to the stero shop that installed it for the previous owner and they thought the CD player was bad, so I'm going to have a new unit installed next week.
Thanks for all the advice on my problem.
Old 07-21-2016, 02:55 PM
drsfmd
drsfmd's Avatar
Since you aren't losing power, my guess would be that whatever anti-shock technology is used in the head unit has failed.
The easiest way to deal with that is to go solid state... I bought a head unit that will accept an SD car behind the faceplate, and I digitized my CD collection.
Quick Reply: 1992 aftermarket stereo loses power?
