help with oil leak on 1990
i have a 1990 corvette, im having trouble locating a oil leak, at first i thought it was the valve cover but cant find any wet spot when i feel around, there seems to be oil on the bolt that secures from the exhaust manifold that also secures the dip stick tube ,i thought maybe it was for sure the valve cover and dripping down but i cant locate any oil there, any help would be much appreciated
I suppose it could be blow back from a worn engine coming back thru the tube. MKE SURE THE STICK IS FULLY SEATED, KEEP AN EYE ON THAT. Hard to say with so little info. A big leak? small drop on the driveway every time driven? using, or going thru oil? miles on
n engine, ect. Please excuse any typos, just had a small STROKE AND HARD TO SEE SCREEN/LEFT EYE.
ghostrider1 - here's for a full and speedy recovery -
