Getting clutch done and tranny is stuck to
spline. Have my 89 in to get the clutch done and the tranny is stuck to spline and they can't separate said it will only separate an inch or so, does this sound right has anybody had an issue like this?
Did my 94 last week and if tranny is not supported/aligned properly it will bind. I had to adjust the trans jack and the use a bar to gently separate the trans from the bell housing.
Once you have cleared the splines you can then lower the rear of the tranny
Are they trying to remove transmission with bell housing still attached or transmission from bell housing? Since they can move it an inch I betting with. I would unbolt trans from bell housing first, remove transmission, and then remove bell housing. Does car have flood history?
Don't think its ever been in a flood but i wonder if he hasn't got it supported right. There is no difference unbolting this trans than any other v8 of its vintage i am guessing there can,t be anything he is missing? I will take off work early tomorrow and see if i can see anything.
There was one in here a while back on the ground. He hooked his truck to them apart.
Now if they are trying to pull the bellhousing off the back of the engine, the pull style clutch pressure plate and throwout bearing are locked together and will not come apart as is normally expected with a more conventional push style clutch.
Hope this helps.
canuck buick (08-26-2016)
mechanic said the throwout bearing was seized on the spline, but i was still able to shift and change gears just would slip under heavy throttle does this make sense if the throw out bearing was seized on?
The trans needs to come straight back until the front shaft of the trans clears the clutch disk usually just a few inches.
Throw out bearing doesn't ride on splines it rides on front bearing retainer. It's the metal collar, that input shaft protrudes from, the throw out bearing slides back and forth on it as clutch is applied.
Your mechanic just isn't familiar with how the Corvette ZF clutch works. The clutch is a PULL type release. The throwout bearing is captured behind the fingers of the pressure plate and the pressure plate is bolted to the flywheel flywheel. You CANNOT pull the transmission and bell-housing off as a unit with the clutch release fork is still in there because it is captured in the pull type throwout bearing. And you can't get the fork out without removing the bell-housing. All he is doing by pulling on it, is pulling on the fork and releasing the clutch just like pressing on the pedal does. When it reaches the end of the throw, that's as far as he can pull it without breaking something like the release fingers in your pressure plate or bending your fork and ruining your expensive hard to find throwout bearing. You have to remove the transmission from the bell-housing FIRST!
