Trans Fluid Change??? to DO or NOT
Hey Guys I surfed the forum for alittle and couldn't find anything on really if I should change it or leave it alone! I also feel dumb, but cant find the how much the pan holds and Where to add the dang FLUID!!!! I have an 87 C4 with an AUTO trans it has 116xxx miles and it runs fairly well!
trans
Received 3,043 Likes
St. Jude Donor '05
Not sure on capacity
The dipstick should be towards the rear of themotor on the passenger side. make sure its not the engine oil. It should be pink not black
X2 no sense in doing it if its clean but if its new to you it wont hurt the car just your wallet.
Check the fluid level while its running, in park a few minutes once youve stopped driving the car.
Had some strange issues (sticky solenoids, 4l60e) and was convinced by a well known shop to have him powerflush the system and put a bottle of Lucas stop slip in along with the fluid of course. Been good for 2 yrs now about time to do it again.
This was after dealer and 2 trans shops told me I cooked my trans which by the way changing your fluid will not ruin your trans like the internet would have you think. If its gone its gone.
VikingTrad3r (09-17-2016)
now to answer the OP question, seems to me, when I changed out my 700R4's filter, I had to add approximately 4 quarts of fluid, so i'd say that's about what the pan holds. as far as where to add fluid, rear, RH side of the engine is the transmission dipstick - that's where you'll add the fluid. you will need a small funnel. note: the area of the cross hatching on the dipstick is one pint. to check the fluid level - at idle, in PARK, on level ground, operating temperature, check and adjust level accordingly. everything should be covered in your owners manual.
Last edited by Joe C; 09-17-2016 at 07:36 PM. Reason: mis-typed -- PARK not neutral
vette196 (09-20-2016)
My notes say 7 quarts for a pan removal.
Don't forget to dig the filter O-ring out of the pump. It's usually stuck in there really tight.
well i might just do that then. im putting a trans cooler in and was going to do the whole flush thing by running the car and drain the atf out the return line while filling down the dipstick till it comes out clear
If dropping the pan, the fluid loss will be approx 4 quarts. I would start with 3.5. It's a lot easier to check and add than remove fluid.
So, if you dump the pan, add a gallon and you add say 3 more quarts, run the engine till you get about 3 quarts of fluid out, fill up 3 quarts and repeat. That should get everything out of everywhere. After which you fill to level.
I think a lot of those are a "Hail Mary" thing. They neglect the trans, it shifts bad so they try a fluid change. When that doesn't work, the fluid change screwed up the trans.
Where do I find Dextron II again?
IIRC, it is up to Dextron VI now.
Yea, but thats an exact photocopy of the old specs. Would hope they had Dexron II on it, unless they could tell the future...
Also, for the OP, heat kills a lot of autos. Installing a transmission cooler might help out, kits for the cheaper ones are usually around $100 or so. Sometimes bit more, sometimes bit less. Just don't want to go too cold for the trans or that could hurt it too.
St. Jude Donor '05
aklime I agree most those additives are snake oil
in the vehicle I posted about I bought it new so no prior owners let it go
changing the fluid problem still persisted;powerflushing it and just adding fluid same thing
Wasnt til it was powerflushed and that stuff added it went away plagued me for yrs even the dealer didnt have an answer. whatevers in it works or just hit lotto odds but a $10 can of it once every other yr wont kill me
FWIW - never added snake oil products to my 85's 700R4 - usually do a filter service every 4 to 5 years or 30K-40K miles, and a complete flush (w/ filter) at 100K. bought the car in 1995 with 33K, and currently at 157K on the clock -- absolutely no noticeable issues with the transmission. seems to have relatively firm, smooth, shifts. I figure with continued care, I hope to get to the 250K mark without problems. BTW, I've always used the ac delco service filter/kit (still made in the USA - ).
