Auto transmission filter
MLaw (10-02-2016)
not sure if you're looking for delco, or another brand, but here's a couple sources. personally, I use ac delco OE service replacement, on my 90's and 85 700R4's -
http://parts-catalog.acdelco.com/cat...log_search.php
http://www.rockauto.com/en/catalog/c...ic,filter,8600
Advance Auto will have high grade filter, tell them what car is and have fun with bolt above pass side exhaust clamp,be sure to replace seal in valve body,very hard to remove but can be done.I had to use a good seal removal tool to extract old seal.Have first aid kit nearby.
Finding the correct transmission filter for this application can be confusing because there will be filters listed for both "shallow pan" and "deep pan". You need the shallow pan filter. I very recently purchased a WIX #58879 filter for my 1996. I have not installed it yet but the quality is great and it came with a nice looking rubber gasket.
FWIW, if it means anything to you, purolator transmission filters are made in china.
