Downshift problem.
Old 10-17-2016, 10:16 PM
phDiesel
phDiesel's Avatar
Default Downshift problem.
96 LT-4 6M
I'm having trouble getting into 1st in my car.
It won't let me in until I'm under 4mph. Anything above that and it grinds.
Also if I'm sitting stationary I can't just jump into 1st. I need to shift into 3rd or 2nd first, and sometimes when I do go to engage first it's like there's a hard barrier but all I need to do is let the car roll a few inches and it will engage fine. I'm hoping it isn't the synchro and I just need a fluid service but I'd like some advisement.
Old 10-17-2016, 10:20 PM
antfarmer2
antfarmer2's Avatar
Fill your fluid in your clutch it is under the puter on the drivers side.
Old 10-17-2016, 10:22 PM
phDiesel
phDiesel's Avatar
I should mention I've done a Slave Cylinder and Master Cylinder replacement and the fluid has been serviced within the past 2,000 miles.
Old 10-17-2016, 10:27 PM
antfarmer2
antfarmer2's Avatar
Then pump it up and hold for five minutes then slide your foot off and let it snap back. Might take a few times to get all the air out.
Old 10-17-2016, 10:29 PM
phDiesel
phDiesel's Avatar
I'll give it a shot in the AM, Thanks!
Old 10-18-2016, 03:38 AM
Cliff Harris
Cliff Harris's Avatar
Your symptoms indicate that the clutch is not releasing completely.
Old 10-18-2016, 08:15 AM
kg4fku
kg4fku's Avatar
on both accounts.
You either have air in your hydraulic system, due to a leak or not getting all the air out after replacement, or you have a bad slave/master cylinder.
Did you follow the bleed procedure for the hydraulic system when you replaced the slave and master?
Recommend a visit to ZFDoc's site and doing a little reading.
http://www.zfdoc.com/clutch_hydraulic.htm
Old 10-18-2016, 10:00 AM
Tom400CFI
Pro Mechanic
Tom400CFI's Avatar
Received 3,181 Likes on 2,322 Posts
I agree with the advice given above too, but would ask this:
How much pedal "free play" is there? In other words, how far will the pedal move downward under your foot, before meaningful resistance is felt?
Old 10-18-2016, 12:38 PM
phDiesel
phDiesel's Avatar
I'd say probably 3/4-1" or so.
Old 10-18-2016, 12:55 PM
FAUEE
FAUEE's Avatar
Received 4,444 Likes on 2,802 Posts
Why are you shifting into 1st anyways? There's really no reason to shift into 1st unless you're stopped in this C4... Especially with an LTx engine... ESPECIALLY with an LT4!
Old 10-18-2016, 12:57 PM
Tom400CFI
Pro Mechanic
Tom400CFI's Avatar
Well that doesn't sound bad...seems like it's bled/and hydraulics are working but it cant hurt to check anyway. When is the last time the trans fluid was changed?
Old 10-18-2016, 02:01 PM
Klondike
Klondike's Avatar
I had a similar problem and it was a loose ball pivot point on the clutch release fork. The looser it got, the farther I had to push the pedal before it would release. It finally got so bad that the fork would scrape on the back of the pressure plate and make a horrible noise! Unfortunately to fix that, I had to remove the C-beam and drop the transmission to gain access to the inside of the bell-housing where that pivot ball is.
To Downshift problem.
Quick Reply: Downshift problem.
