Alternative to Race Ramps?
Home built with 2X10s and Rhino Ramps along with some left over wood.
I put hook and eye latches so I can easily detach the approach ramps. I use a garage sale mirror so I can watch the front of the ramp as I drive on. I use a Jackavette to lift the rear and then lower on jack stands:
UsmcKaz (12-08-2020)
BV85 (10-27-2016)
IMHO ramps are a PITA unless all your doing is changing oil.
HF has a 3ton floor jack with 20" lift for 100 bux. Get 4 of 4 leg jack stands with ratchet stops. Avoid tube or pin type stands.
To jack up a Vette:
Use the floor jack @ the left or right front jack point @ the rocker, raise the car & place a 4x4 or stack 2 or 3 short lengths of 2x6 under the wheel. Lower the car on the wood stack, locate the jack under the center cross member & raise the car. Jack stands in place the rear can also be raised.
To jack up a Vette:
#34
To jack up a Vette:
To jack up a Vette:
#35
Finalist 2020 C4 of the Year - Unmodified
To jack up a Vette:
Raise whole side at point under side mirror, put stands front and back, repeat on other side.
Repeat a few times if need to go really high.
No cross stress on the body.
I agree, jack stands make more sense since wheels off is step three for a lot of work.
Ramps would be nice for oil, transmission fluid and radiator burp.
#39
Former Vendor
Heavy Duty Race Ramps 2500# per ramp
Reverse Logic has been selling Race Ramps with a Heavy Duty option since 2011. They are rated at 2500 pounds per side.
https://www.reverselogic.us/shop.htm...egory=17900487
#40
7th Gear
