help 93 w/ major power loss and rear noise.
6th Gear
Hi vette friends, having a problem with my 93 LT1. Took it for a rip 2 days ago started feeling a odd feeling in my rear.
it's was shaking and wobbling with a little bit of noise. I did research bad differentials it doesn't sound like that so much. Could it be there is no oil in my TC the reason to all my problems I having.
Would this cause why I have a major loss of power what happen when I step on the pedal the car lags even is hesitates were it feels like it has half the power with a bogging sound. I just had a full turn up one oil change ago and recently inspected. The morning I checked all my hoses, wires and fluids. I find out my clutch fluid was really low so I filled it an went for a rip still having that noise and major loss of power. No light came on wit in That 4 miles. I know it can be 10 different things or just one thing with signs to a big thing just don't know and could use some insite an help. This being my 1st vette I'm still learning and need some veterans wisdom with c4s.
I would check all your fluid levels including transmission and diff. You will want to check color and odor. A Qtip in trans and diff fill holes should be able to give you indication. Black, grey, metallic or smells burnt something is broken. While wheels are off ground see how smoothly they spin and if there is play in hub bearings. Not sure what TC is
PC2301 (10-21-2016)
Pick it up and check your fluid and feel for play in your drive and bushings. For the bogging change your o2s.
PC2301 (10-21-2016)
6th Gear
6th Gear
