New Project, 1985 c4 z51 4+3
That's correct, I was talking about the slave cylinder only. They corrode internally over time (just like the C2-C3 Corvette brake caliper does) and the fluid will leak out and the slave will not fully depress the pressure plate to release the clutch disc.
Here's a good picture of the clutch master/hydraulic line/slave set up on the early C4.
http://tech.corvettecentral.com/2007...1996-corvette/
Good luck... GUSTO
Good luck... GUSTO
I have used balance beads with great success in my pickup and plan to use them in my Vette when I put on my C5 wheels and new tires. I have an 86 and am trying to figure out the right spacers to run my C5 wheels. Do you have part numbers for those adapters you ordered? Are you happy with the quality?
Good luck... GUSTO
Good luck... GUSTO
Received 3,043 Likes
St. Jude Donor '05
Nice score
Yank that TPI sell it with the 4+3 if lsx stuffis that cheap go for it dont look back.
If youre a machinist Im looking for a dirt cheap 02 5.3 core for my pos truck. Not sure if I can use a 6.0 with the 4l60e pm me if you got something
yep thats the plan, ls6 is being built for it right now. but likely keeping the 4+3 for now. $$$ dont allow for a tremec yet lol
#35
stock block, crank, rods, pistons, king main bearings, king rod bearings, king cam bearings, 243 ported and polished heads, heads flycut .010, gmpp asa road race camshaft, holley aluminum version of the ls6 intake, it is match ported to the heads, and it is match ported to the throttle body. 78mm ported ls6 throttle body and maf, longtube ss304 headers, cai, 42lb injectors, ls3 road race oil pan, arp main studs, arp head studs, arp rod bolts, arp engine bolt kit, etc etc etc....
#36
T5 transmission.... gonna tear it down and rebuild it for good measure.
post script, also has a hurst short shifter kit on it.
C4LS6 (12-04-2016)
#39
ls6 is 405hp stock, but with heads, cam, intake, cai, longtubes, and a good tune, im hoping for 475-480hp ballpark. but regardless of what it turns out, it should be a blast!!!
