C4 headlight
Go with the plastic gear instead, I was going to go with the brass but other forum members explained to me, it'd be better to have the gear as the weakest link, as it's only a 15 dollar part on ebay
Your plastic gears lasted 30 +/- years. Why do you want brass? Do you really have a gear problem? What bump stops?
Welcome to the Forum! We're here to help!
Welcome to the forum and do not use metal gears the motor and worm gear will cost alot more.
welcome aboard- I just bought my 1985 this past August and had to replace my gears as well - I used the plastic gears from Zip if I remember correctly, cleaned everything added a little grease and was good to go
I like brass myself. Plastic grows old and can crack. Who knows how long they will make the part? Everyone talks of the weak link but I'm not sold on that. I have seen posts of the cracked pucks or bump stops or whatever you call them but hardly hear of the gears breaking after service as a "weak link".
What year? http://www.corvetteamerica.com/cf/di...3A%20headlight
Let me be your 1st. Headlight quit opening and I purchased new pellets and took unit apart. At first glance pellets still looked new (8 years old). Then I saw the gear cracked. All is well again.
The gear is plastic and old. Cracking is probably going to happen sooner or later. Mine had spider cracks. Did the steel worm gear ever mash the plastic gears?
The 1st ones lasted 22 years and the plastic gear was still good. I did change it and the non-existing pellets. The second one the gear just cracked on its own. The material it was made of was defective I guess. It had one crack from the teeth to the center which let the gear expand. Just a freak thing. (I hope)
During his C4 classes Gordon Killebrew recommends switching from glass headlights to plastic ones. He passed both around the class and you could really tell the difference in weight. It makes sense to use them as they will cause less strain and wear on all the headlight motors, gears and buttons.
From that standpoint, I would agree however, the question is how much more stress will the metal gear cause vs plastic? Is it significant in that it pushes the envelope of the motor? Also, as I asked before, how long do you think that they will keep making the gear? We have a vehicle that is over 20 years old and the aftermarket will not always be there. When the plastic gear has issues, I'd much rather not have to hear "NLA" and have to search ebay for a salvage unit.
With all due respect to GK, while I agree that plastic is better for the motor (not sure how much better), I have to ask if he thought of the availability of the item in the future.
Fair enough. A possible sacrifice. My issue is that I wasn't sure if it would be manufactured for much longer. Also this is not what I usually hear which is the pucks disintegrate. I replaced mine with brass and kept the plastic ones for spares. Happens to be I looked at it and found some hairline spider web cracking on the plastic
It was a good move to replace them when I was there. I didn't notice it at the time till much later when I checked carefully and with a bright light behind, I saw some hairline cracks in the gears. Just a cursory look and you probably could miss it.
Time to switch to LED. What does anyone think of the weight of http://www.ebay.com/itm/162081918608?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT or http://www.ebay.com/itm/252631632700?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT? Probably be lighter.
I suspect the company went out of business. Great product while it lasted. He was cool about it a few years back when I had issues. Took it back and redid the connectors and the left was and still is good. I need the right side taken care of but if his site is down, IDK how to reach him. Hence I need to find a replacement. It seems that playing perdiddle in WI gets me a "fixit" ticket.
