heater core Q
heater core Q
hey everyone - as I am debating the to replace the heater core now or later - I wanted to know if anyone has used a spectra aluminum or pro source brass/copper heater core from auto zone? I am a little skeptical because they seem inexpensive - but I found rock auto's to be even less
does anyone have any experience with either or another recommendation - the job seems really involved - one that you do not want to have to do again - so I want to be sure before I get started if possible -
any help is greatly appreciated
Sean
Sean
Sean
Sean
sb66 (12-04-2016)
thanks - from what I have read it is an ambitious undertaking
- if that core works, it is reasonably priced - so I would be out more in the time area than the money area
Sean
Sean
Get those window lock clips from the help area at autozone( probably break the old one at the temp adjuster door)
A long extension 1/4 inch and instead of inserting a ratchet use a
large allen head wrench in it to turn that will just give clearance to
upper left screw(bolt). I left that one out and no harm has come.
Good luck
sb66 (12-04-2016)
spectra will need to be bent.
https://www.corvetteforum.com/forums/c4-tech-performance/3832281-sos-help-on-early-c4-heatercore.html
and
https://www.corvetteforum.com/forums/c4-tech-performance/3833152-exact-match-heater-core-whos-bought-one.html
spectra cost me a crapliad of my time and lots of anxiety. will never buy another.
my recommendation is to get your oem copper one rebuilt.
and
sb66 (12-05-2016)
Rock Auto has TYC brand lifetime warranty, Could not find anyone else with this warranty,that being said I have not needed to replace my heater core, but if it goes that's what I'll use just my 2 cw.Good luck with repair.
Moderator
CI 5-6-7-8-9-10-11-12 Veteran
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18-'19-'20-'21-'22-'23
When I replaced the heater core in my '85 years ago, I ordered a OEM AC Delco core (can't remember where I got it). It's a job you only want to do once, so make sure you buy a top quality core. I removed mine by taking out the passenger seat and removing it from the bottom. Tedious...but not impossible.
Have never seen a parts warranty that covers labor for any part.Only by some repair shops that install parts provided by them, and then not very often,part only no labor,but if you can suggest a parts co. that has that warranty let us know. Thanks
