Let's see who has the best C4 (custom or stock)
Received 4,504 Likes
U.S. Air Force
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Haha, yeah it has a custom RPO code.
Head and cam LS1 built 700r4 3:73 gears it's pretty quick. I've had it for a lot of years so it's been a work in progress for a long time. Still more I'd like to do to it but I've moved on to other cars so it doesn't get much love.
U.S. Air Force
If you can do that, love to see your next project!
Double din wasn't that bad. Just some mild trimming and it fit fine. I still need get the new center panel that's designed for the double din for a "perfect" fit around the face.
The android io board was about $30 best I remember. It allows you to control pretty much anything. I have relays controlled by it and analog inputs to read the sensors on the motor. I didn't get the new display finished to replace the warning lights section in the center of the dash before the weather got bad and I covered the car up for its rest till spring weather. So that will be one of my first projects when the weather warms up.
The display I went with has uv protection and anti glare coating so it should do ok in a car environment. Time will tell on that part.
I bought it off the net last year. Several places sell the android io board including the place that makes it.
The screen I found a link to when I was looking at mp3car for ideas. The display unit isn't mounted yet but it is in the car which is covered up for the winter. Plus we are supposed to have a record snow fall today. Well record for Alabama
Once spring gets here I will drag it out back out and finish it and do a howto with links to what I used on my site.
Here's a link to what I have done so far. I don't think I posted any of the android io stuff yet since I count the screen as part of that project so its technically not finished since I don't have the screen installed yet. But it may be on there under mods.
http://crowz.narmir.com/vehicles/198...e-convertible/
I've posted the story here before, so I'll go with the lite version. This was my Mom's 96; when she passed away about a decade ago, I "adopted" it to ensure it stayed in the family. Bone stock (except line locks and a D44 rear-end), all original (except some touch-up paint on the nose).
I think it's about to hit 30K miles. That's 30K, not 300!
im nominating 5abi vt's admiral blue zr1.
https://youtu.be/VRGp8u6ugEU
best looking c4 ive ever seen. his thread is incredible.
The following 4 users liked this post by 85 Stalker:
95tealconvert (01-07-2017),
Cblock406 (05-05-2022),
Mike Holmen (06-20-2017),
Raidmagic (06-24-2017)
85 Stalker has a very nice setup. I like the Black Lingenfelter Box especially with the C4 Logo on the cover. Good Thought on that one.
The dash is also a great setup. My dash is going to be pretty much laid out like 85 Stalker's dash.
Ok, as promised here is the list of mods to my “Basically Stock” 1989 C4. It would probably be quicker to stay what was not modified because I don’t think there is anything left that is stock. Also I included a couple of more pictures.
POWERTRAIN:
Lingenfelter All Aluminum Dart SBC 427 646 HP with AFR 245 Heads, Lingenfelter Special Grind Comp Cam, and a bunch of Super Zoomy Go-Fast engine components.
TPIS Miniram with 1250 CFM Monoblade Throttlebody.
10 Qt. Aviaid Drysump Oil System with Custom Sump Pan
Jones Racing Products Front Drive System with Alternator and Power Steering
Lingenfelter Custom Air Intake System with K&N Cone Filter
Be Cool Radiator
Holley HP EFI System Tuned by Autotrend EFI
Tilton Triple Disc 5 ½” Clutch with Flexplate and Reverse-mounted Starter
TPIS Headers Coated with Mike Maier, Inc. Custom Exhaust
Tremec TKO600 Roadrace Tranny with Sidewinder II Shifter
Dynotech Engineering Carbon-Fiber Drive and Half Shafts
Gladiator 44 Rear Diff with Tru-trac Posi
SUSPENSION:
Vette Brakes and Products Front and Rear Custom Spring Rate Composite Mono Springs with Ride Height Adjustment
Vette Brakes and Products Rear Camber and Tie Rods and Dog Bones with Heim Joints
Penske Triple Adjustable Shocks with External Reservoirs with Mike Maier, Inc. Custom Design valving and Reservoir Mounts. Shocks serviced annually by Mike Maier, Inc.
Mike Maier, Inc. Custom Front Adjustable Swaybar with remote adjuster
Mike Maier, Inc. Adjustable Upper Control Arms
Baer Six-Piston Calipers with 14” Two-Piece Rotors on all Four
Forgeline GA3R Wheels – 18X11 Front 18X12 ½ Rear
BF Goodrich Rival S 315-18 Front & 335-18 Rear Tires
EXTERIOR BODY:
Front Hood – Carbonfiber with Fenders extended out 1 ½” each side by Ken’s Custom Paint & Autobody
Headlights – Breathless LeMans Style
Rear Fenders – Extended Out 2 ½” each side by Ken’s Custom Paint & Autobody
Rear Bumper-Carbonfiber with Custom Spoiler by Ken’s Custom Paint & Autobody
Rear Window-Carbonate by Five Star Composite Bodies
INTERIOR:
Mike Maier, Inc. 6-Point Custom Cage with easy Exit for Driver & Passenger
Momo Seats
Momo Steering Wheel
JCG Customs Instrument Panel with Speedhut Gauges (GPS Speed, Tach, Oil & Water Temps, Oil Pressure, Volts, Fuel Gauge, Turn & Hi Beam Indicators, to be completed at the end of this month.
POWERTRAIN:
Be Cool Radiator
SUSPENSION:
EXTERIOR BODY:
INTERIOR:
Momo Seats
Momo Steering Wheel
The following 4 users liked this post by Nokones:
1993C4LT1 (01-10-2017)
