View Poll Results: Cat less
Multiple Choice Poll. Voters: 6. You may not vote on this poll
1995 corvette cat less
In my car, the catless or gutted cat option made more noise than necessary. I have been pulled over because the cop thought it was too noisy and they have a noise ordnance. So what are you meaning by "problem"? Will the car have an issue? Your's might have an "after cat" O2 sensor so you will need O2 sims to make it run without throwing a MIL. It might encourage a cop to take a closer look at you. It won't gain performance
I doubt it would. Maybe if you cat was completely plugged. You can run the car with open headers and I have doubts it would happen. As to back pressure, I think there issue might be that if you have too low a back pressure by dumping a large pipe, you might lose scavenging which hinders mid range performance.
Don't need a sim for this anymore, you can use spark plug non foulers. I used to have a MIL due to inefficient catalysis, but haven't had an issue since installing the spark plug non foulers on the after cat O2s.
