Suggestions on bellhousing bolts?
The more I work on my cars the more I'm starting to hate GM or at least the engineers who designed them. I figure I can get the bottom bolts with some extensions but I'm having a hard time with the top ones. Any suggestions on a particular tool setup that may help?
I was trying both 9/16 and 14mm combo wrenches and also a 1/4 dr ratchet which I can't get to fit with how the bolts are too close to the firewall.
When I removed my transmission, I went to the tool store and bought 4 "el cheapo" 9/16 boxends from the bargain bin. Heated up the end with a torch and made 4 progressively bigger bends. A bit of experimenting will find you two that will work in conjunction with each other to remove the top bolts. Tedious but doable.
I had always wondered how i would pull the engine in my car until i had to pull the transmission.
Now i know i can pull my transmission in under an hour!
Pull drive shaft, pull support beam, lower transmission a few inches, pull cooler lines, lower transmission more, easy access to bell housing bolts!
