Newbie needs Diagnosis Help
#41
Replaced fuel pump with no change, replaced fuel pump with no change. I am over it at this point. I also tried the old mist the plug wires in a dark garage while its running to check wires for arcing (yes its that desperate now) Also has been hooked up to a computer multiple times now and everything seems to be reading good. I guess if there was anyone in the blue springs area that had a car with a compatible computer to swap out to see if that makes a difference?
#42
Well when I changed the opti I ohmed the spark plug wires, they checked good. Problem now solved with a new set of wires. I guess I should have just replaced them from the beginning. Problem solved now.
#43
Glad to see you figured it out!
