Fuel Gauge
Fuel Gauge
I filled up the car for teh first time the other day it was showing 3/4 at the time.
After filling it, it read full. After driving about 70 miles it still showed full. So I stopped and filled up again. It took 4 gallons.
Is the fuel gauge staying at full normal?
Mine does that although I haven't counted the miles. It will begin to move more rapidly through the middle. Never let t get to the point when the check gauges light comes on... you're on less than fumes!
FOURSPEEDVETTE (02-27-2024)
Zen Vet Master Level VII
My experience is similar as I can drive for about 50 miles before it nudges from full.
I never take gauges as gospel but fill up after about 300 miles give or take,
Mine does not move till 100. And get over 400 per tank.
7/8 when full
I’ve used Techron to sort out the gauge going to zero and it worked .
When full it only reads 7/8.
Any idea if continued use of Techron would remedy it ?
I’ll try nonetheless.
