Windshield rock chip repair kits
I assume everyone has used these kits offered by various manufacturers to repair rock chips on their windshields. My question centers around the resin used in these kits. Instructions say to expose the repair to sunlight and on cloudy days to expose it longer. What exactly cures the resin? Is it ultraviolet rays or heat or....
I have a chip in the windshield on one of my other vehicles which I sustained yesterday. I wanted to repair it forthwith given the fact we are still getting below freezing temps during the nite hours and upper 40's during the day - which equates to temperature changes that could expand that chip into a crack...
Problem is we most likely won't see any sun for the next few days so I was wondering what technique I should use to allow the resin to cure faster. Will heat do it? If so, I can just warm up the car and set the defrost on high.
I don't have a heated garage.
Any thoughts suggestions would be appreciated.
If you have full coverage insurance, check with your company before doing any repairs yourself. Some companies waive the deductible for chip repair, Nationwide does. We had a chip in the pickup truck, called Nationwide claims, they said to take it straight to one of the approved glass shops and there would be no deductible.
Don't waste your $$$. I used one on my wife's car, did everything per instructions and the crack is still showing, plus it can no longer be repaired by a pro. The good news is that the crack didn't go anywhere, but its definitely not repaired. Do it right and you won't pay later.
Call your insurance agent. Many policies will do the injection repair for free and will both a record and usually some form of warranty of the repair. Insurance did one for me, took under 30 minutes from what I remember.
I used one of the home kits earlier on another vehicle. It did work but why bother when there are better options available.
I am a retired tractor trailer driver. Rock chips were common. Every chip I had was fixed by pros. Lasted the life of the windshield. ( Some chips were breaks that required replacement but ones that were just chips lasted more than 50,000 miles till truck was sold
I used one of those kits on my Vette last summer. Found it worked just fine and looked like a pro did it (had a Jeep where I needed chips filled 4 different times). I really just wanted to try it myself and the chip was in a spot where I could tell if something didn't go well. Drove it all last summer and no issue's.
I have done more than 50+ chip repairs, if you get a quality kit, and are OCD level meticulous with your prep work you should have no problems. I never liked doing the job if the chip was within 3 inches of an edge. Clean, clean, clean, the glass you don't want a speck of dirt trapped in the repair.
don hall (03-25-2017)
