Flashing signs, Warning lights ! Low fuel warning
The other day when I got home for work, looked at my fuel gauge and it was reading about 125 miles left. I figured I would fill up the next time I take it out. This is the lowest I have ever let it go. Yesterday, weather was nice my son and I were going to basketball practice. The gas station was only about 2 miles away. In those 2 miles, my gauge went from 120 miles down to 24 miles, the reserve warning came on the little lines started blinking, the check gauges popped on. The car gauge definately drops quick and alot of warnings let you know you are running out of gas lol.
I know mine drops (based on the bars) faster towards the end than when it is full but that is kinda rapid a drop. OTOH, I don't place any value on the "Lie-O-Meter" when it comes to guessing the range. I just go by the bars. Doesn't matter how low you let it run. Nothing bad will happen. Your weiner won't fall off.
Did you happen to look notice how all the other instrument and dash lights (radio, HVAC, etc.) were behaving at the time? Were those dimming too? This all happened to me once in my 96. Ended up being a slightly loose negative battery cable. Check yours first...
Nope, didn't notice any of that. I myself try not to let any of my cars drop below 1/4 tank. Now I know where the drop starts on my vette.
Flatulent Dwarf
I've always been told that with in tank fuel pumps one of the purposes of the fuel was to cool the pump...although mine has run down to about 25 % a couple of times it wasn't there long. Maybe if the pump was getting a little warm it aggravated an existing condition. Although I'm sure you probably know this, the fuel tank on our cars is hardly linear...big on the top and narrow towards the bottom.
later, tiny
later, tiny
later, tiny
later, tiny
If you believe that old wives' tale, you can also make sure that your battery doesn't sit on the bare concrete.
Flatulent Dwarf
I've been told the same thing. I choose not to listen to old wives' tales. Someone who ran a test got the pump to burn out after over 30 minutes of continuous running with no fuel. How long does your motor run without fuel again? Without fuel to load the motor, for all we know it is over spinning but for the test he didn't factor that.
later, tiny
https://www.corvetteforum.com/forums...post1590728908
Post 39 but you can scroll backwards to see it takes a LONG time
