C4 DIC information lens - blank sheet??
Does anyone know where I can buy a tinted/dark plastic lens, similar to the DIC lenses our C4s have? Does not need to be corvette specific, and must be blank. This is for a project. Ideally, I'd like it have the same properties as our DIC ones (tinted, translucent, flexible, can be cut to shape, thin ~approx 1mm).
The lens is actually a transparency of some color and the matte finish you see is an application over that with a % of filtering. I believe that if you actually had a need to use ICONS, LETTERS or whatever you use a transparency of your desired color then maybe use a "window tint" to the % that you'd like.
The advantage I'd think is that until you arrived at what you actually wanted you could work with "scraps" from a window tinter. I'd think you want a conversation with someone that does residential/commercial tinting and NOT automotive orientated. I believe there's many more "privacy" levels available and inventoried. I had no problem working with samples when I was wanting to do some light filtering for residential glass. Their scraps are sometimes "huge"!!
You would have the transparency/lens, on the backside the ICONS/LETTERS "filter" and on the face the window tint.
