1993 turn signal lever removal
Old 03-24-2017, 02:42 PM
funbooker
funbooker's Avatar
Default 1993 turn signal lever removal
I need to take my turn signal lever out of its socket. I see posts that say just pull it out but when i apply the amount of force that seems to be just on the verge of breaking something, it doesn't budge, actually it moved a little bit but then stops.
Before I break something, I would like someone who has done this before to confirm that I just need to pull harder.
Old 03-24-2017, 03:32 PM
hcbph
hcbph's Avatar
This is where the FSM is invaluable (not breaking something). I believe they just push in but don't take that as fact. If nothing else, see what a replacement looks like, but definitely get a FSM.
Old 03-24-2017, 03:54 PM
funbooker
funbooker's Avatar
Agreed. i just try to avoid owning things that just take up space for most of their lives. (I'll avoid the divorce comment that comes to mind.)
Speaking of shop manuals, I could use a blow up of the things that go on the column. I knew how they went the day I took them off but as this thing drags on, I'm not so sure what went on first.
Old 03-26-2017, 08:49 AM
kalister1
kalister1's Avatar
The stalk will just pull out. It has a short (2 to 3inch) cable that connects to a another connector that sends the Cruise Control functions down the column. The connection is inside that little box just behind the stalk.
Old 03-26-2017, 11:06 AM
funbooker
funbooker's Avatar
Thanks, I'll muscle it out. Now does anyone have the blow up of the stuff between the column and the airbag?
Old 03-27-2017, 09:01 PM
Mayor111
Mayor111's Avatar
Received 1,954 Likes on 941 Posts
I can share any pages from a 92 or a 94 (sorry no 93)...
Would that help and if so, which year would you prefer?
Ill post pictures once I hear back from you...
Old 03-28-2017, 11:59 AM
funbooker
funbooker's Avatar
I have no idea whether they changed anything in the steering column in those years. My best coin flip guess would be 94 is close. There's really just a ring or washer I'm not completely sure about. Posting would be much appreciated.
Old 03-28-2017, 01:23 PM
Mayor111
Mayor111's Avatar
Here are a few screen grabs from the 94 volume - I hope this helps:
Old 03-28-2017, 03:07 PM
funbooker
funbooker's Avatar
Thank you for doing that but the part I need is just the column from the yoke in your pictures to the airbag.
Old 03-28-2017, 03:12 PM
Mayor111
Mayor111's Avatar
Did I miss the sections you need or did I provide more than what you needed? I'm ok if I provided more...if I missed what you need please let me know.
Old 03-28-2017, 03:29 PM
funbooker
funbooker's Avatar
If you could post the steering wheel and air bag, it would probably be covered. Thanks.
Old 03-28-2017, 03:49 PM
Mayor111
Mayor111's Avatar
Can you PM me your email - for some reason its not letting me upload any of the new pages I have - sorry!
Old 03-28-2017, 03:59 PM
funbooker
funbooker's Avatar
wrynotme at gmail
Old 03-28-2017, 04:05 PM
Mayor111
Mayor111's Avatar
Email sent - with 5 pages attached...Let me know if you need any additional pages...Glad to help!
To 1993 turn signal lever removal
Quick Reply: 1993 turn signal lever removal
