Adding TPI to 1970 El Camino
I'm adding TPI to my 1970 El Camino my question is, my wine harness is made for a 89 to 92 Corvette most of the harness was marked except for a green with white stripe wire... Can anybody tell me where this wire goes?
Several years ago Hot Rod magazine published articles on how to add a TPI to any Chevy small block. I have seen it on line so you should be able to find it with a search.
If you know exactly what year your ecm/harness is you can go to www.alldata.com and get access to a gm service manual for that year car.You can print from it .You have to pay $24 but if your in a jam the correct info is priceless.
These are L98 possibilities
1227165/16198259 is the most common for '86 to '89
1227727/16198260 for '90 & '91
An L98 if it were a F-body could be
1227730/16196344/16198262
LT1 '92
16159278
Here's nearly all of the very popular L98 TPI ECM PIN-OUTS and configurations. See if this helps you!
http://chevythunder.com/fuel%20injec...%20pinouts.htm
