Brake Fluid Dot 3 vs Dot 4..?
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Can someone tell me what the difference is between Dot 3 and Dot 4
1. Are the compatible?
2. If used in an older system would you need to flush the system be for changing?
Thanks Steve
Thanks Steve
Re: Brake Fluid Dot 3 vs Dot 4..? (We Gone)
DOT 3 is better...
DOT 4, if I remember rightly, is better for storage.
I use Valvoline SynPower. Its a synthetic brake fluid. Works very nicely!
Re: Brake Fluid Dot 3 vs Dot 4..? (Mylzi)
Why not DOT5? There is silicon free DOT5 too.
There are a lot of DOT3 fluids that have excellent wet/dry boiling points. I use the Ford HD fluid on the street and ATE Super Blue for track use.
See the bottom of this thread for some good info on fluids and their boiling points: http://forums.corvetteforum.com/zerothread?id=340111
St. Jude Donor '16
Re: Brake Fluid Dot 3 vs Dot 4..? (c4cruiser)
Thanks for the link.. thats what I needed to know..
