OptiSpark Help!!!
OptiSpark Help!!!
I am looking to buy a 92-95 Vette and been hearing alot of people talking about problems with the OptiSpark.
How can I check if it is working well?
How much does it cost to repair or must it be replaced?
:banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead:
[Modified by CanadaVette, 9:29 AM 2/27/2003]
Re: OptiSpark Help!!! (CanadaVette)
If the car is running good, the OPTI is working fine.
Cost is anywhere from $1200 to have it done to less if you do it yourself. Don't forget to do the water pump when yoiu do the OPTI :cheers:
1 Post
St. Jude Contributor
Re: OptiSpark Help!!! (Rex Ruby)
Don't let that scare you away from a good deal. The original opti may last over 100k miles. Mine went out on my '92 at around 105,000 miles. I replaced my own along with plugs, wires, ignition modual, water pump, hoses, etc, etc. It's not that bad of a job, the opti can NOT be installed incorrectly. One only needs to be carefull and follow the manual. If you don't plan on wrenching on your own vette (somepeople don't like to) the opti alone shouldn't be more than $700 at the dealer. Hope I've helped ! ! ! !
:steering:
[Modified by edsalinas, 5:58 AM 2/27/2003]
:steering:
If its running good you should be ok. Look for oil/coolant leaks @ the front of
the engin if it very bad could be trouble ahead for the opti.
About 350$ from Jeff Kopp, 450$ Corvette Central with vent kit installed.
YES you can mess up a opti install, I have heard on this fourm of guys not getting the shaft keyway lined up and forcing the unit on.
I have replaced mine, the hardest part was removing the balancer.
GOOD LUCK. :seeya :flag
OPTIS DIE PREMATURELY when they get wet from big puddles, the waterpump drips on them or the intake leaks oil on them.
Lots of contacts on the web for optis, Dealer gets about $400-$500 though and a few hours to put in. I would say it should cost you about $700-$800.
$1,200 is highway robbery.
SORRY my bad, the Corvette Central 92-94 Lt-1 Opti with vacuum asperation
sys. # 274583 IS 625$ You can do this same mod. @ corvettefever.com go to tech section under opti-options.
Re: OptiSpark Help!!! (xlr8nflorida)
BUT IT STILL DIDN'T WIPE THE SMILE OFF MY FACE.
:steering: ;)
[Modified by 94lt1torchred, 12:57 AM 2/28/2003]
Re: OptiSpark Help!!! (94lt1torchred)
The dealer lists them at $649.00 :crazy: I got the dealer down to $450.00 but it turned out I did not need the opti. I only needed a water pump. If the car is runnning fine..you do not need the opti.
1 Post
Thanks for all the help
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
:cool:
If your interested in seeing what the optispark looks like dissected and how one is removed..heres a link!
http://www.charm.net/~mchaney/optisprk/optisprk.htm
JJL
[Modified by ncsugreywolf, 1:36 AM 3/3/2003]
JJL
