Gas Tank Filler Recess
Old 04-14-2003, 12:27 AM
NBM LS1 M6
NBM LS1 M6's Avatar
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17-'18-'19
Default Gas Tank Filler Recess
There is the little "hole" in the gas tank filler recess that drains any excess rain water or gasoline. Where does that lead? Is there a hose that drains to the ground? My gas tank filler recess hold standing water after I have washed the car, etc. Can that "hole" be cleaned to drain more quickly?
:confused::confused:
Old 04-14-2003, 07:35 AM
CentralCoaster
CentralCoaster's Avatar
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default Re: Gas Tank Filler Recess (NBM LS1 M6)
On mine, it makes two 90 bends and drains on the left sid, underneath the bumper.
Mine was doing the same as yours, and I managed to unclog it by blasting the hose nozzle into it. It seems to be clogged partially, and slow to drain everytime I wash the car, which is about weekly.
Old 04-14-2003, 08:10 AM
NBM LS1 M6
NBM LS1 M6's Avatar
Default Re: Gas Tank Filler Recess (CentralCoaster)
:cool::cool: I'll give that a try. Of course, if it is a weekly problem, I can understand the problem. Partly the design. Besides, the thing eventually drains or dries. It's just a nuisance if one fills the gas tank right after washing the car or whatever.
:eek::eek:
:seeya
Old 04-14-2003, 09:59 PM
HG
HG's Avatar
If it's clogged, that's a good way to possibly get water in the gas tank. Try getting a garden hose close enough to get water pressure in the hose. I had a copper adapter used for ice maker hook up which was 1/8 copper pipe. That fit into the drain hole and cleared it out. :hurray:
Old 04-15-2003, 10:10 AM
85vetteguy
85vetteguy's Avatar
If you have access to a compressor, shot some air through. That should do the trick, Guy
Old 04-16-2003, 03:08 AM
Teh Nam
Teh Nam's Avatar
Default Re: Gas Tank Filler Recess (85vetteguy)
:iagree:
this worked for me!
To Gas Tank Filler Recess
Quick Reply: Gas Tank Filler Recess
