Any Tips For Removing Rust From Rotors?
Does anyone know a quick and effective way to remove rust from rotors. Once removed, what helps keep it from coming back? Thanks for any suggestions.
Re: Any Tips For Removing Rust From Rotors? (CG77VETTE)
Yes I would like to know that also.
We went to look at a new car for my wife (BMW X5) and the rotors were COVERED in rust....the car had 36k on it....I asked the salesman why they were so rusty and he told me it was "flash rust" and it was their because the car had not been driven in a week which I think is :bs He said it would be gone after we drove it a few days :rolleyes:
I showed him my "91 Vette with 30K miles on it that does nothing but sit and asked him why my rotors were nice and shiny and the $40K 1 yr old BMW's rotors were rusty.....
So has anybody ever heard of "flash rust"?
Re: Any Tips For Removing Rust From Rotors? (Bodhi)
Re: Any Tips For Removing Rust From Rotors? (konroh)
you vette probably sits inside a garage right? I think the rust the poster is taking about would be rust on the hub, which builds up over time. Most cars i have seen that are sitting outside have rusty rotor surfaces, goes away after a few stops...
My rotors (82K miles) had rust on the hats and were really rusty around the edges and into the fins. I sandblasted them at work and they turned out pretty nice. It was easier than I thought to keep the grit from hitting the brake pad swept area - I cleaned them up without any masking and without scouring up the smooth surfaces.
There was a post in a thread several months ago that mentioned boiling the rotors in de-ionized water (I think), which would turn the metal black and prevent further rusting.
I have seen people paint them with hitemp paint, usually black, to keep the rust from coming back.
Looks good too.
Looks good too.
Re: Any Tips For Removing Rust From Rotors? (Eric 96)
Very good question Eric. I looked at several grocery stores and walmart recently for deionized water, no luck. You would think the parts places would handle the water manufacturers recommend for coolant systems, I haven't seen any.
I cleaned them up and painted them with gloss black Rustoleum over a year ago. I didn't even use high temp paint and they still look great :yesnod:
Location: Michigan in the summer, Florida the rest of the time
St. Jude Donor '08-'09-'11
Re: Any Tips For Removing Rust From Rotors? (TA)
Brad
Re: Any Tips For Removing Rust From Rotors? (GS Ragtop)
I used a brush. It was a piece of cake.......took off wheels one at a time, cleaned calipers and rotors and then painted them. Probably took about 20 mins a wheel :cheers:
Received 1,400 Likes
Get the rust off with an SOS pad or sand it or whatever, then paint the hub with a thick coat of hi-temp paint.
Location: Minnesota in the summer, Las Vegas in the winter
Re: Any Tips For Removing Rust From Rotors? (sraft)
Re: Any Tips For Removing Rust From Rotors? (vader86)
Sandpaper and Wire wheel worked real well for me. Then use High Temp Paint
[Modified by Corvette1996LT1, 1:01 PM 5/30/2003]
Re: Any Tips For Removing Rust From Rotors? (brdd)
Perchance are you thinking about distilled water? :skep:
It very well might have been distilled water, or maybe something weird(er) like vinegar. I just can remember with certaintly - that's why I added the "(I think)" in there. I even went back and did a search on brake rotors to try and find the topic, but had no luck. I remember reading the post and thinking that it would be interesting to try when I get my new rotors.
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
It sounds like your boiling trick is putting a passive oxide layer (black) on the iron. Deionized water can't do that! It has no dissolved minerals or free ions (which cause oxidation). I'll believe it when I see it.
Easy way to keep the rust off... paint em.
I didn't even worry about masking the rotor surface carefully. A few quick stops buzzed the overspray right off. I used BBQ paint, and a hi-temp semigloss coat on top of that. But guys using plain ol rattle can paint don't seem to have durability problems with the paint either.
Location: SCMR Rat Pack'r Charter Member..Great Bend KS
I may be stupid....but where do I get De-ionized Water? :confused:
You can buy black oxide kits that will put a durable black finish on ferrous alloys....try http://www.reidtool.com and look for "tool black kit". They run about $60. This makes me think that it would take more than DI water to turn iron black......
Larry
code5coupe
:seeya
[Modified by rocco16, 2:08 AM 5/31/2003]
Re: Any Tips For Removing Rust From Rotors? (rocco16)
Yeah....I had the same problem...bought four cadmium plated (gold), drilled PowerStop rotors...man, they rock !!! truly looks high peformance
