Door Panel Removal (1991) - Just double checking
I found a great link describing the door panel removal and I just wanted to double check with people who have done it. Specifically my question is about the screw behind the window switch. I just pry out the switch with a small screw driver?
I think a CF member wrote this up. They did a great job! http://www.corvetteactioncenter.com/....php?qstId=161
-Mike
-Mike
Re: Door Panel Removal (1991) - Just double checking (Mike in Boston)
I did not remove the lock cover. Just push it up enough to get a philips screwdriver past it. Then when I put the panel back on I left this one screw out so I wouldn't stress it when I needed to remove the panel again.
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
I did my 92 last summer. The window switch should pop out. If I remember correctly i used a small screwdriver and popped it out.
All the locations marked look right. :yesnod:
Re: Door Panel Removal (Blue 92)
Great thanks guys. That'll be one of my projects today. The door was "slim jimed" a while back and the lock doesn't quite lock unless you push the slider the rest of the way manually. Hopefully it'll just be a bent rod or something.
-Mike
-Mike
Re: Door Panel Removal (Mike in Boston)
My wrong. I was talking about the door lock. I pryed one up enough to get past it, but the other door I had to pry off the door lock. As to the window switch, I don't think the screw behind it has to be removed to remove the door panel.
Good link.......I've taken the doors off so many times just to do silly maintainance stuff that I can do it blind folded.......lol....... :crazy:
