Answers from the C4 Guru (Gordon Killebrew)
A few of you wanted me to ask Gordon some questions when I took his C4 class at Bloomington Gold. Bear with me as it has been years since I took any college class notes and I might have made 1 or 2 mistakes: Q: Why only 1 muffler outlet when there are 2 tips. A: To meet EPA noise guidelines. Note: 87/88 Z51 do have 4 open outlets. Q: Why are you so sure the toothbrush was invented in W. Virginia. A: In any other state it would have been called a teeth brush. :jester Q: Why are the rubber gaskets so expensive? A: They are made from foam that is covered by neopreme and are costly to produce. Gordon says to go with GM parts and order the 95/96 sets. They are the latest designs and are cheaper than replacing crappy aftermarket stuff later. Q: 88 has different front shocks than other C4s. A: For ride height. (my notes are kinda scribbled here but I think he said all years will fit the 88) and all Z51 and 88 on up had gas shocks.. Q: 85 still hesitates after doing all the recommended updates suggested in his school. A: Call him - you have the number. Q: Why no drain plug in diff? A: Just cause Dana made em that way. Use a suction gun and refill with synthetic and two (2) bottles of GM additive - you will be good for 100K. Just a couple of other things. The 1984 Corvette is the best bargain out there. Have it tuned by a shop that knows what they are doing (such as Ron Kane in Springfield, IL http://www.kaneauto.com ) The car has fewer computers and is less complicated and will run great if tuned properly every 50K. Change your auto tranny fluid to synthetic and do a full flush and filter at the time. Happy Corvettin!
:blueangel: You may reach Gordon at http://www.gordonkillebrew.com
Re: Answers from the C4 Guru (corvetteronw)
Thanks Corvetteronw! You must take great shorthand! I know Gordon is hard to follow when he gets started. I kept hollerin' slow down, slow down!
Again, thanks :thumbs:
Re: Answers from the C4 Guru (Ramrod92)
Is his server down or something? :steering:
Location: SCMR Rat Pack'r Charter Member..Great Bend KS
Thanks, Ron!
This forum is the best.
Even though I know Gordon sidestepped the answer to my question on the diff drain (GM tells its vendors exactly what features they want in a component...GM designs the component, the vendor just builds it to the customer's drawings....), the other questions/answers were quite interesting.
Thanks for sharing.
Larry
code5coupe
:seeya
[Modified by rocco16, 6:19 PM 7/4/2003]
Thanks for sharing.
Larry
code5coupe
:seeya
Threadkiller
Cruise-In 9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Re: Answers from the C4 Guru (Darth Vader)
Darth Vader wrote:
"The 1985 is really the best bargain."
Not agreeing or disagreeing, I'm just curious as to how you came to that conclusion....
Re: Answers from the C4 Guru (tobijohn)
Received 1,406 Likes
Noise guidelines :rolleyes:
Re: Answers from the C4 Guru (myscx)
2 bottles of GM additive, I thought it was supposed to be 1???????
Re: Answers from the C4 Guru (vader86)
