What is the red lens lamp underside of rearview mirror?
underside of my interior rearview mirror, the driver side of it has a small slit lens red in color with a tiny bulb behind it. The two courtesy lamps on underside of the mirror work when I flip the switch on passenger side underside of mirror, but I've yet to see this red light illuminate.
When does it come on?
Is it supposed to come on automatically?
How do you manually turn it on?
It doesn't come on with the two under mirror courtesy lights, but the bulb appears intact.
Fuses look okay.
<edit> P.S.: or is it some sort of sensor? (has bulb behind it though...)
:confused:
[Modified by Lone Ranger, 10:21 AM 7/30/2003]
Fuses look okay.
:confused:
Location: No more yankee my wankee, the Donger is tired!
1 Post
Re: What is the red lens lamp underside of rearview mirror? (Lone Ranger)
It should be a light that illuminates at night t olight up the shifter console area.
Re: What is the red lens lamp underside of rearview mirror? (Jeffvette)
Re: What is the red lens lamp underside of rearview mirror? (tgroghan)
It comes on with the headlights and lights up the shifter. Most of the people that have them were suprised to find it...
1 Post
Take a look at your right forearm the next time you are holding the shifter and your headlights are on, you should see a dim light on your skin. That is the light your are refering to. You should have only one map light on the mirror too.
Re: What is the red lens lamp underside of rearview mirror? (87vette)
In the 94-96 cars it is orange to match the dash and instrument lighting. I was told it was an interior ambience light. I have had to replace that bulb only once in the seven years I've had my 96. :cool:
Location: Minnesota in the summer, Las Vegas in the winter
The item is question is an extraterrestrial homing beacon for alien ships. Turn it on and you will likely end up being dissected by something with two heads.... :leaving:
Red?? Shouldn't it be clear?? :confused:
Re: What is the red lens lamp underside of rearview mirror? (IGOFASTERINMYVETTE)
Re: What is the red lens lamp underside of rearview mirror? (rainsux89)
mines orange.
i finally drove my car last night in the dark. very cool in there.
wanted to just sit in awe in the garage but afraid the wif would tease me :lolg:
