burp cooling system
Old 11-07-2003, 09:41 AM
ronbod
Cruising
ronbod's Avatar
Default burp cooling system
How do I Burp the cooling system after it has been drained ? I am getting the low coolant indicator occasionally but there is lots of juice in the system. :steering:
Old 11-07-2003, 09:55 AM
86_RedRider
86_RedRider's Avatar
Cruise-In V Veteran
St. Jude Contributor '03 & '05
Default Re: burp cooling system (ronbod)
run the car until the t-stat opens all of the way and then shut it down. repeat this about 3 times. i think stock t-stats are 195. you could also drill 2 small holes (1/16") in the t-stat to skip this process. i did it on mine and never had to burp the system after a flush.
Old 11-07-2003, 10:00 AM
AGENT 86
AGENT 86's Avatar
Open rad cap and start engine. Let it warm up till thermostat opens. Either have someone depress gas pedal or reach over and hold the throttle about 2000 rpm. The increased flow will lower level in rad. Add coolant till full,cap it and let off the gas. It may require this a couple of times to fully fill the coolant system.
:cheers:
Old 11-07-2003, 10:39 AM
ronbod
Cruising
ronbod's Avatar
Default Re: burp cooling system (AGENT 86)
Thanks. I'll try that. What is the coolant recovery bottle for? I thought it was a reservoir that the system called on when the level was too low.
Old 11-07-2003, 11:51 AM
vinnies87
vinnies87's Avatar
St. Jude '03-'04-'05-'06-'07
:cool: :cool: Thanks nice to know.... :thumbs: :thumbs:
Old 11-07-2003, 03:22 PM
Steel Blue 91
Steel Blue 91's Avatar
It allows coolant to flow into it when it gets hot and siphon’s back as it cools without introducing air into the system.
To burp cooling system
Quick Reply: burp cooling system
