Thermostat removal???
Do I have to remove the plenum to change out my thermostat? One of the two bolts holding down the thermostat housing is about 1 inch long. Don't know if this will get in the way. :confused:
Re: Thermostat removal??? (Mikez40)
Mikez40 is correct. One of those bolts is actually a stud which provides an injector ground. Just make sure it goes back the same way it comes off.
Re: Thermostat removal??? (Muffin)
That sounds right. The bolt that I said was about 1 inch long does have a ground wire hooked to it. Thanks alot. :thumbs:
