VATS Problem
VATS Problem
Can anyone help me with the location of the VATS module on a 1993 - I have ordered the VATS bypass module from Baker Electronix but the directions are rather lacking... car has been down for two weeeks and I really would like to get her going again. Thanks in advance for any assistance... btw the instructions say to tap into the Fuel enable wire (VATS Signal) or (circuit number 229) usually a dark blue wire at the PCM, typically pin 25 or 30 on the red connector or pin 55 or 70 on the blue connector. The fuel enable can also be found on the BCM's 10 pin blue connector #230 postition E. This data is useless to me without a manual or some generous and knowledgeable forum member.
Location: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
I thought my Vats was failing on my `87 coupe. It left me stranded a few times. Long story short, it turned out to be the alternator. It wasan`t keeping the battery fully charged. I replaced both it and the battery, & so far, so good. Starts every time
Ken :flag
Ken :flag
