Lug nut torque and Impact Wrenches
OK, I always use a torque wrench to set my lug nut to 100# but I would like to use an impact to make the job quicker changing wheels so often for AutoX. I picked up a new impact wrench that stated 260# or torque, got it home and with 100 psi into it it wouldn't budge a single nut. No better than the cheap impact that came with my compressor.
OK what gives. The spec says 260# of torque so I would assume it could remove a nut tightened to 100#. I'm going to return it as it serves me no purpose but what would I need for this job? I'm not sure I understadn the rating on the wrenches
Any recommendations.
Large Impressive Member
Location: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Even a POS impact wrench ought to break loose lug nuts torqued to 100#. What brand, type of torque wrench are you using and are you sure of it's calibration? I would still recommend final tightening w/ a good torque wrench unless you are in need of Nascar type pit stops.....
Elite Torch Red Member
When I tighten my lug nuts by hand they are already at or more than 100 ft/lbs. I know this because when I put teh torque wrench on it clicks immediately.
Although it does take more effort to remove. Maybe if you carck them first then use the impact wrench to finish it would still serve a purpose.
I have an impact wrench that is adjustable on the amount of torgue it puts out. Possibly yours does to and it is set real low? To change the torgue on my gun you twist the **** that sets the direction. Mine is an Ingersol/Rand
you can buy torque extensions that are made just for that.they flex at a preset torque.snap-on has a 3 piece set of the common ones.
you can get individuals at napa.
ever notice your local tire shop using a blue plastic coated 1/2in x 6in extension?thats what it is.
260 ft pund impact is a mediocre tool ,(i like the 450 carbon fiber ingersol),but it should be fine for lug nuts with a torque extension on it.
if it wouldnt take off the lug nuts you torqued to a hundred then theres something wrong with it.
look close for the regulator adjustment on it and make sure its in wide open position,you have 120 pounds of air pressure going in to it,test your torque wrench.
you just need a known weight around 50 punds.measure out from the center of the ratchet head to the end of the handle.if its 2 feet then 50 lbs hangin on it should be right where it clicks when set at 100 ft lbs.
if its 18 inches either do some math or slide a pipe over it and hang the weight at 24 inches.liquids make good weights.(jug of water,oil etc..)
you get the idea.
i would just get the torque extension and leave the torque wrench for the headbolts.
good luck
you get the idea.
good luck
The impact I am using in a Campbell Hausfield, don't know the number. I know it isn't the best but I'm just looking to take off 100# lug nut that I agree any impact should do. I couldn't find any adjustment for the reverse position, it has 3 speeds/power for the forward position. I did some looking at the website and found something interesting. Each impact has a rating that includes the size of the nut? Maybe the torque rating is based on the size nut and that force changes based on the nut? I know that doesn't makes sense based on my knowledge/understanding of what torque is. This is one of the ratings.
380 foot pounds of torque for fast removal of stubborn bolts up to 9/16" in size
I don't want to use a breaker bar or other tool to break them loose then use the impact, tool many tools for a simple job. I guess I need to keep shopping and maybe I'll find one that will work.
St. Jude Donor '05
Your lug nuts may have been put on at a dealer (Firestone, Goodyear, etc.) and if so they use the Godzilla setting which is WAY over 100#. I have taken mine back when they were hard to get off and made them re-torque (is there such a word?) all lug nuts to 100 pounds. They broke a stud once, and wanted ME to pay for it, but after words with the manager, they replaced it at no charge. The history in their computer helped as it showed that I had requested 100 pounds, and they had not followed my request.
Location: SCMR Rat Pack'r Charter Member..Great Bend KS
Check that out before you toss the impact wrench.
The suggestion about the torque-limiting extensions is an excellent one. Try www.mcmaster.com for a nice selection.
Larry
As for the flow or CFM, I am using standard fittings and standard high pressure air line, can't remember the size. This is the same setup I use with for building my basement driving my framing nailer, its a 25g 6hp Husky compressor and I set the pressure to 100-110 when trying to use the impact. I thought all the standard type fittings that plug into the quick release ends would allow for these normal tools to operate effectively.
My die grinder, air chisel, and air rachet work fine. only the impact struggles and I know the nut are at 100# as I put them on myself with a quality torque wrench.
Sure seems like this is overly complicated for trying to take the wheels off more efficiently.
What me and my buddy did when we took his car to race in Memphis, I cracked them loose with the lug wrench and used a cordless drill with the proper size socket attached and spun them off, and spun them back on with the drill and used the torque wrench to finish them off.
Quicker then by hand, but slower than just using an impact wrench.
You need...
100 ft/lb: http://buy1.snapon.com/catalog/pro_d...re&dir=catalog
80 ft/lb: http://buy1.snapon.com/catalog/pro_d...re&dir=catalog
65 ft/lb: http://buy1.snapon.com/catalog/pro_d...re&dir=catalog
Socket, Impact, Deep, Laser Marked, 3/4", 6-Point
These are all 1/2" drive.
These torque limiting extensions look to be a great tool for putting the wheels on, but my biggest problem is getting the impact to break them loose.
I guess I'll give one additional impact a try, but I'm not looking to spend $150 on an impact. I'm looking for a midprice model maybe up to $75. If that won't do it then the manual method will be the way.
I have gone through the same as you. Got the $30 home depot special and it wouldn't budge the nuts. Had to go to Lowe's and the IR models are much higher in quality, I went with the $140 model though they start at about $80 and others are on ebay all the time.
Mine is not a Sears model, but it is a 12 volt jobbie that I bought some years back and it has yet to fail to remove ANY wheel nut including my neighbors gunked-up off-road truck wheels, rust and all.
I also have an electric. Picked it up off ebay. This one will either go into the lighter, or has an attachment for the battery. With the way I have been fighting a break problem over the past couple of weeks, it has had a lot of use with no problems. If you are talking changing tires at the track, this doesn't need the compressor.
Location: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
I also have the Campbell impact set. It would not remove a bottle cap, let alone a lug nut. I went to Wal-Mart, & bought their 1/2 drive air gun & a length of 5/16 air hose, ( $49.00 for the gun, & $ 11.95 for the 50` length of hose). Much better now.
