1996 LT1 A4 gear ratios
Old 08-31-2004, 11:49 PM
Jman
Jman's Avatar
Default 1996 LT1 A4 gear ratios
What rear end ratio(s) were available in the 1996 LT1 A4? This is for a friend of mine, he just bought it.
Thanks-
Jeremy
Old 09-01-2004, 12:00 AM
wildman378
wildman378's Avatar
I have a 95 and it's the same for 96....you have the standard ratio which is 2.59 then an optional ratio which is 3.07 most have the 2.59. Mine has the 3.07s and the way you can tell is look at the rpo codes if you see G92 AND G44 it has 3.07s if you don't see that he has 2.59's. Oh and the ratio is also stamped on the diff.
so he has either one of those 2.
Quick Reply: 1996 LT1 A4 gear ratios
