Convertible Top from plastic to glass window
St. Jude Donor '04 &'05
I have a 91 what is needed to go from a plastic window to a glass window.
Originally Posted by 96zride
Thanks, what exactly does the kit do? If it is just to hook up the rear defrost I could care less.
In addition to the retrofit kit ($) and the glass window top ($$$), my weatherstripping didn't survive removal, so I replaced that as well ($$). Many people also replace the headliner at the same time (but I didn't). It quickly adds up!
But it's WORTH IT!
Originally Posted by 93convtLT1
purchased the retrofit kit from GM $115. The top from ebay 350$ and gaske kit $250 from ebay. 8 hours later all is better than new
[QUOTE=Strick]Sure wish you'd write a tech tip on what you did. You did do it all yourself?[/QUOTE
Already a C4 tech tip
https://www.corvetteforum.com/techti...=117&TopicID=2
