1994 6spd, what rear gear ratio? - CorvetteForum - Chevrolet Corvette Forum Discussion
C4 General Discussion
General C4 Corvette Discussion not covered in Tech
Old 01-12-2005, 12:20 PM   #1
Firevette
CF Senior Member
Cruise-In X Veteran
Firevette's Avatar
Default 1994 6spd, what rear gear ratio?
What rear gears were offered in 94 with the 6 speed? Anyone know of a database anywhere with this information for different years etc?
Firevette is offline   Reply With Quote
Old 01-12-2005, 12:49 PM   #2
VR'92
CF Senior Member
St. Jude Donor '03
VR'92's Avatar
Location: I'm the walkin dude I can see all of the world...
Most likley it is a 3.45
VR'92 is offline   Reply With Quote
Old 01-12-2005, 01:03 PM   #3
Firevette
CF Senior Member
Cruise-In X Veteran
Firevette's Avatar
thanks! did they all come in this ratio? or was it an option?
Old 01-12-2005, 02:04 PM   #4
95PoloVert
CF Senior Member
95PoloVert's Avatar
All M6's came with 3.45.
The A4's came with 2.59's, with the 3.07 optional.
You can verify the ratio by checking the bottom of the diff case. It should be stamped, along with the date installed, etc.
95PoloVert is offline   Reply With Quote
Old 01-12-2005, 02:06 PM   #5
Perfusion
CF Senior Member
Perfusion's Avatar
Bingo...
Perfusion is offline   Reply With Quote
Old 01-12-2005, 02:07 PM   #6
Firevette
CF Senior Member
Cruise-In X Veteran
Firevette's Avatar
Thanks!
Old 01-12-2005, 02:24 PM   #7
kwik_ta
CF Senior Member
kwik_ta's Avatar
Location: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
didn't the 91 or 92 come with 3.54's??? I know one year had an off ration than the others.
kwik_ta is offline   Reply With Quote
Old 01-12-2005, 02:55 PM   #8
Z-07 freak
CF Senior Member
Z-07 freak's Avatar
Location: Why are there squished peanut butter cups in my underware?
That's correct for the `94 model year.
Z-07 freak is offline   Reply With Quote
Old 01-12-2005, 02:59 PM   #9
jrzvette
CF Senior Member
jrzvette's Avatar
Location: The reason time exists is so everything doesn't happen at once
Quote:
I think the 84 4+3's and the 1990 ZR1's came with 3.54's, all other manuals were 3.45. (correct me if I'm wrong)
jrzvette is offline   Reply With Quote
Old 01-12-2005, 03:25 PM   #10
bogus
CF Senior Member
In the C4 Tech FAQ, there is a link to the C4 RPO FAQ.
Check that... This has been beaten to death... trust me on this.
bogus is offline   Reply With Quote
Old 01-12-2005, 08:36 PM   #11
ZF Six
CF Senior Member
Support Corvetteforum!
ZF Six's Avatar
ZR1s had 3.54s, I don't know about the '84 4+3. I know for sure that 1989-90 6 speeds had 3.33s, then in '91 they bumped it to 3.45 and it was like that until the C5s came out, on 6 speeds.
ZF Six is offline   Reply With Quote
Old 01-12-2005, 08:54 PM   #12
bogus
CF Senior Member
Check this link:
http://forums.corvetteforum.com/showthread.php?t=956104
And this link:
http://forums.corvetteforum.com/showthread.php?t=956100
The 1990 ZR1 was the only year with the 3.54 - they went to 3.45 in 1991. It could explain why the 1990 has been considered the quickest of the bunch.
Old 01-12-2005, 11:24 PM   #13
Z-07 freak
CF Senior Member
Z-07 freak's Avatar
Where are you guys coming up with ZR1s having 3.54s?
The `89 prototypes? Yes.
But the others?
Old 01-13-2005, 01:51 AM   #14
jhong321
CF Senior Member
jhong321's Avatar
But the others?
I have heard that the cars that where made for the outside market (not uS) had the 3.54 and all the us cars had the 3.45. Correct me if i am wrong
jhong321 is offline   Reply With Quote
Old 01-13-2005, 02:06 AM   #15
bogus
CF Senior Member
Old 01-13-2005, 03:23 AM   #16
BlackbirdZ07
CF Senior Member
BlackbirdZ07's Avatar
My '92 6 speed LT1 came with 3.54 gears FROM THE FACTORY. The RPO code is GH0. I don't know what years that GH0 was an option, but it was available in 1992. By the way, mine is a US car, so this was not some export-only option.
Unfortunately I don't have access to my C4 Corvette Specs book, but it has all this kind of information.
BlackbirdZ07 is offline   Reply With Quote
Old 01-13-2005, 11:23 AM   #17
Z-07 freak
CF Senior Member
Z-07 freak's Avatar
Quote:
Originally Posted by bogus
That's an `89 prototype. All 84 of them have the 3.54 axle ratio.
Old 01-13-2005, 02:46 PM   #18
bogus
CF Senior Member
answers that, eh?
Old 01-13-2005, 04:02 PM   #19
Z-07 freak
CF Senior Member
Z-07 freak's Avatar
Not really,
Just curious where you got that from.
Old 01-13-2005, 04:25 PM   #20
Vis Croceus
CF Senior Member
Vis Croceus's Avatar
Quote:
It only shows up in the online RPO lists for 89-90.
Vis Croceus is offline   Reply With Quote
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • 1994 6spd, what rear gear ratio?
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    speedometer gear prestige6 C1 & C2 Corvettes 5 12-28-2014 02:20 PM
    Rear end gear ratios jacked cobra C6 Forced Induction/Nitrous 5 11-01-2013 08:02 PM
    What is the stock rear gearing on my 05 C6 A4 Rayzzz C6 Tech/Performance 8 06-13-2010 08:16 PM
    What is the stock Zo6 rear end gear ratio? Lvnspeed C5 General 7 02-23-2010 07:49 PM
    Rear end gear ratio question jodenesvette C6 Tech/Performance 11 09-02-2008 10:28 PM
    Tags
    1990, 1992, 1994, 6speed, axle, c4, code, corvette, gear, gears, location, ratio, rear, stock, zr1
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
    • Ask a Question
    What's your question?
    Send
