1994 fog light bulb replacement
2nd Gear
Does anyone know how to change the fog light bulbs on the 1994 LT1? Must the whole front face be removed? Turn signal bulbs can be removed easily thru a cut out, but fogs can't be reached thru the same cut out. Also the unit can't be pushed out thru the front since it's larger than the opening. I'm going crazy
Originally Posted by 94newyork
JACK UP FRONT GET UNDER AND LOOK YOU WILL SEE A SMALL DOORWAY LIKE FLAP DROP IT DOWN YOU WILL HAVE ROOM FOR YOUR HAND
Jacking it up a little bit makes a world of difference to see what your doing and getting better access to it. The bulb is a standard #896. If I remember its a quarter turn release/tighten.
2021 C6 of the Year Winner - Unmodified
You might want to check out this thread and upgrade those fog lamps while you're doing it. http://forums.corvetteforum.com/showthread.php?t=971305
Fog light replacement
upgrade to the higher wattage.
