can MAP/TPS sensors test good but still be intermittent?
Old 03-03-2012, 10:57 PM
mcm95403
Support Corvetteforum!
mcm95403's Avatar
Default can MAP/TPS sensors test good but still be intermittent?
Hi Guys,
I'm posting in this section because my questions are specifically EFI related and I'm thinking those who hang out in here would have the best info.
I have a 91 with an odd problem. I recently did an ignition upgrade (cap/rotor/Taylors plugs) and had the cap break during install. Since then I've had a misfire condition. It gets worse when hot, and isn't there at all when dead cold. So far I've:
replaced the broken cap and rotor the next day, but there was an hour of drive time - this helped a lot
replaced my injectors with a set of Bosch III's from FIC - this helped a lot
also fixed some vacuum leaks at the same time
replaced the o2 sensor - not much improvement
since doing the injectors I've been able to re-add the wires - more improvement
replaced the igniton module in the distributor - again, helped more, but still missing
Today I replaced the fuel filter and did the throttle body bypass - again, it's running better, but still has the miss - although not nearly as much as before. I also pulled the AIS motor, cleaned it and the housing well - it idles much better now.
I tested the MAP sensor today and it appears to be good, but my questions concerning that and also the TPS is: can a digital VM really show an intermittent/worn contact area in these sensors? It seems that the meter doesn't respond quickly enough to show what is really going on.
I'm almost to the point where I think I should replace the MAP, TPS and IAT sensors just because they're all 20 years old. The car has no codes. I'm also wondering if it's possible that the broken cap could have let the MSD coil arc to the internal wiring and damage the computer and/or sensors. What do you guys think?
Prior to the ignition "upgrade" the car didn't show any signs of the misfire. Mileage per the dash was pretty steady at 23-24 @65 on a fairly level road. Seems like a similar cars get about 28 so I'm thinking that something electrical is still screwy.
Also, with all these fixes, the car pulls quite well at full throttle, although you can still feel a miss as the RPM's climb.
Pics of the cap damage:
Old 03-15-2012, 03:00 PM
mcm95403
mcm95403's Avatar
http://forums.corvetteforum.com/c4-g...g-sensors.html
Old 03-15-2012, 10:50 PM
VenkmanP
VenkmanP's Avatar
Originally Posted by mcm95403
I recently did an ignition upgrade (cap/rotor/Taylors plugs)...Since then I've had a misfire condition.
What happens when you put the original parts back on? (i.e., take off the bad parts you installed)
Old 03-16-2012, 12:22 AM
mcm95403
mcm95403's Avatar
It gets worse again.
Old 03-18-2012, 10:20 AM
jtc44
jtc44's Avatar
Default Testing
I agree that a DVOM can be to slow for a glitch. It might be worth the $ to find a shop that has a osscilloscope and have them check it out for you I got a pico scope and I am still learning it but these things are great for this. The TPS can be intermittent and a good shop can even give you a print out of this.
Old 03-18-2012, 10:41 AM
mcm95403
mcm95403's Avatar
Yeah, I need to see who can do that for a reasonable price. I alreday replaced the TPS and MAP so that's 2 more down.
Old 04-03-2012, 03:21 PM
creekwalker
2nd Gear
creekwalker's Avatar
I had problem similar to yours. rough running. I changed every sensor.. still had problem..Finally checked fuel pump...a small piece of rubber fuel line at the top of fuel pump had small pin holes. Changed fuel line... ran perfect. 1984 model.
Old 04-03-2012, 05:19 PM
mcm95403
mcm95403's Avatar
Thanks Cree, turned out in my case it was a bad (but brand new) spark plug. Changed it and it runs great now.
To can MAP/TPS sensors test good but still be intermittent?
Quick Reply: can MAP/TPS sensors test good but still be intermittent?
