How to silence CCM and Dash 1990 Corvette
Old 05-19-2013, 04:32 PM
captainkawasaki
captainkawasaki's Avatar
Default How to silence CCM and Dash 1990 Corvette
What hex needs to be sent to silence the CCM and dash on a 1990 Corvette? I'm trying to datalog with Tunerpro v5 and am getting crazy data, but I know the hardware is working because Datamaster can datalog without problems. I'm sending 0x56 0x56 0x09 0xB0 currently during connection but that doesn't appear to do the trick. If anyone can tell me what the hex I'm doing wrong I'd greatly appreciate it. (see what I did there, that's an ECM joke--what the hex....)
Old 05-19-2013, 10:17 PM
vetteoz
vetteoz's Avatar
There is a check box in TP to Disable CCM handshake.
Old 05-20-2013, 10:03 AM
captainkawasaki
I saw a checkbox like that in TTS Datamaster but haven't stumbled across it in TunerPro. Can you get me to the menu option for disabling CCM in TunerPro v5? Thanks in advance--GD
Old 05-22-2013, 07:42 AM
captainkawasaki
Just in case anyone else is googling/foruming in vain trying to get TunerPro V5 to datalog on a 1990/1991 Corvette I've attached my working ADX file. I started with JeepsAndGuns edit of Mark Mansur's $8D-1227730 and copy/pasted James93LT1's Connection macro into it. The connection macro silences the CCM and the ABS and lets me get 100% connection rate. Only caveat is that the vehicle must be running (key-on-engine-off is not good enough). I also did not bother to copy the Disconnection macro since when I'm done datalogging I just shut the car off which reset the CCM/ABS silences. Hopefully the ADX will work as well for others as it does for me. --GD
I don't see any upload buttons on here, PM me for the ADX.
Old 12-12-2014, 08:45 PM
aklim
aklim's Avatar
Received 2,214 Likes on 1,928 Posts
What is the check box in TP that I should disable?
To How to silence CCM and Dash 1990 Corvette
Quick Reply: How to silence CCM and Dash 1990 Corvette
