84 e-cell expired?
84 e-cell expired?
Hello, I have an 84 crossfire, and the check engine light stays on but I show no codes with my snap-on scanner. When I went through the data to check the function of all the sensors, I saw "E-CELL - EXPIRED" in the data. I am assuming this may be referring to the internal battery in the ecm. If that is the case, could that be making the check engine light come on? I do not believe I have any shorts causing the light to stay on. Any input would be greatly appreciated, thanks!
There is no battery in the ECM. It uses the car battery for its power.
The scanner has to be configured for the year and model of car to display data correctly. If that is not done then you're looking at garbage data.
Get the error codes:
http://forums.corvetteforum.com/1574918379-post18.html
http://corvettephotographs.com/c4vettes/codes.htm
What they mean:
http://forums.corvetteforum.com/1576116036-post35.html
What they mean:
What they mean:
What they mean:
I never heard of that one before. I did find this:
E-Cell -- This parameter indicates an internal state of the PCM. The E-cell is I used in many system programs to modify the fuel metering and spark timing calculations for a new ("green") engine. The E-cell is an electrolytic cell that contains a silver cathode and a gold anode. As current passes through it, silver gradually depletes to the anode. After a specified time, the anode becomes completely depleted; and the E-cell becomes an open circuit. The PCM then adjusts its fuel and spark calculations for a broken-in engine.
E-CELL EXPIRED should read NO on a new vehicle. After a few thousand miles (varying for different vehicles and engines), the E-cell should expire and the PCM should adjust for an engine that is broken in. After that time, E-CELL EXPIRED should read YES. Newer PCM’s will have a timer for this same strategy.
It came from this page:
http://westersgarageforum.com/archiv...hp/t-769.html?
This is interesting because I noticed something unusual when I got my new 2003 Corvette. After some time it suddenly had a lot more horsepower than earlier. The really interesting part is that I recently bought a 2013 Corvette and it did exactly the same thing. After about 1000 miles it suddenly had noticeably more horsepower. I suspected it was something the factory programmed into the ECM/PCM/whatever to protect the engine before it was "broken in".
I've never seen the inside of an '84 ECM. Does it have a cell like the one described in it?
I haven't had mine apart yet, but in the others I have, that is probably what I thought was the button cell, or watch battery. That's some neat info, thank you for your reply! Now it looks like I have more digging to do to find out what is making my check engine light stay on. I do know that the car had previously undergone lots of ecm swapping and other things before they figured out the problem was a leaky piece of fuel hose in the tank.
I'd like to know what the part number is for this guy.
I did some research on the E-cell and didn't find any data sheets or who the manufacturer is. I assume they made millions of them, so maybe they go by a different name. There are lots of products with similar names so it's difficult to find the correct one.
I did find a document published by Chrysler that had exactly the same wording as the info on the Westers Garage site, so it appears that Chrysler is the source for their info.
I take it your 84 has over 60K miles? The timer will activate at 60K. The “E” cell timer module (turns on Service Engine Soon light (CEL) The 82 module is in the battery box. You can remove it.
