Help Please
Help Please
Here we go vett detectives here are the facts
Put in a new radiator no problems
took it out on a drive ran great
Suddenly water temp climbed from 140 to 200-210
Then driving down the road about 70 started to loose power and died Opened the hood smoke was rolling out from multiple places (kinda white ish)
Checked the oil and had little to none
would not rerfire
took it home on a roll back
Cranked by hand with wrench
Distributor moves as do the lifters
No oil in water and no water in oil
Has fuel pressure like normal also has oil pressure while cranking
Changed
Oil pressure sending unit
Dist Cap
rotor button
Dist Control module
Cranks but will not fire. (same as before
I have not checked the spark yet nor the fuel injector pulse.
Please any ideas are appreciated
would not rerfire
Changed
Dist Cap
rotor button
Dist Control module
What did the smoke smell like? Burnt insulation or coolant? I would be concerned where the smoke came from first and what was the cause. After that, it's all about fuel and spark. You say that you have fuel pressure. What is the reading? Next check for spark. Then folks can help you from there.
Yea, I'd consider 150 psi to be on the low side, but likely "functional". If you're seeing 5 psi, it's going to have to come apart. I'd try to get it out on a stand and start from there.
Yup Im not even worried about the no spark at this point. she is terminal not sure if I want to rebuild or replace.
It's probably getting passed the rings but just to confirm I would do a leak down test and listen to hear where the air is coming out from. Who knows, maybe something messed up with a valve.
There are only a few ways to lose virtually all compression. Rings, valves, pistons and gaskets. If it overheated and started to knock, the rings can be broken (I've pulled them out of one of my old engines in about 1" long sections where they shattered from knocking). If it seized a valve due to lack of oil and heat (or a broken timing chain can do that as well, but yours isn't broken), also no compression (but try a few other cylinders and see if they are all the same). Dead head gaskets (usually you'll get "some" compression and often some water). Or there's a hole in a piston (less common).
Did you try compression on more than one cylinder?
Nope.
