Interior Lights Stay On *1996 Auto Coupe *Please Help*
Old 07-04-2014, 11:40 AM
Bobby Brewsky
Support Corvetteforum!
Bobby Brewsky's Avatar
Default Interior Lights Stay On *1996 Auto Coupe *Please Help*
I used this print out (post #5) to attempt to diagnose my problem.
http://forums.corvetteforum.com/c4-g...lay-timer.html
After jumping terminals A to G, nothing happened per the directions. I then found out that the 1996 jump out is different...CRAP!!! I hope I didn't do any damage, will someone PLEASE CHIME IN?
On to the correct jump, Code C12. It appears that this isn't an issue through research. Following the directions from the above, 1.3 displayed in the trip monitor, then, ENG/MET until 04 is displayed, when the door is open, I read 0 as well as when the door is shut.
I am completely out of my element with electrical, my question is, do I replace the door ajar switch?
Source:
http://keenparts.com/pages/search.ph...x=0&submit.y=0
Old 07-07-2014, 09:47 PM
Red_Vette_93
Red_Vette_93's Avatar
Bobby, those switches are hard to find. I had that problem, just took it out and cleaned and lubed it. The plunger sticks that's why the lights stay on. Easy fix, let me know if you have any problems.
Jim
Old 07-10-2014, 11:32 AM
Bobby Brewsky
I've moved to the General Discussion Section in hopes of getting more replies.
To Interior Lights Stay On *1996 Auto Coupe *Please Help*
Quick Reply: Interior Lights Stay On *1996 Auto Coupe *Please Help*
