Tuners in Houston?
Tuners in Houston?
I recently purchased my first c4, it's a 85 with a 383 l98, 219 cam, super ram intake, Lingenfelter heads. It had a dead cylinder that I found to be a clogged injector. I replaced all the original injectors with 24# accel's and I think now it may be running a little rich. So now I would like to get the car on a dyno and get it tuned. Is there any one who still burns and tunes these ecu's? I would like someone local in North Houston.
85's used a 23.8 lb injector rated at 43.5 psi, but installed with a regulator at 39 psi. Replacing with the Accel 24 lb should be just fine, and still work well within the ecm capability of adjustment.
